Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 39
    Full Member David D's Avatar
    AutoCAD 2010
    May 2011
    50
    Default Text made of objects
    Possibly in the wrong forumn, not sure. Moderators are welcome to move thread if needed.
    I am looking for a way to use objects created from lines and arcs as text because of a machine that will not read text. The objects look like letters and numbers. I am wondering if there is a way to create a text style, library or whatever with the created "text". There can be hundreds of characters on a single drawing so importing and aligning and placing each object 1 at a time is very slow and painstaking.
    AutoCAD 2010
    May 2011
    50
    Found a workaround on this forum page:
    http://cadtips.cadalyst.com/create-text/3d-text
    The first reply shows "txtexp" which does just what I need. Only problem is that for what I am doing I can only use .shx fonts. I would like a slightly less plain type of font but can get by with what is available.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,137
    There are many, many different styles of SHX fonts. Forum member Stykface has a link to over 700 right here at CADTutor. Maybe you can find one that suits your needs. What exactly are you looking for?
    AutoCAD 2010
    May 2011
    50
    We are trying to use a router to engrave on plastic. The router program does not read text so we are trying to take the text that would normaly be printed or laser etched and convert it into actual objects made of lines and curves. I thought the txtexp would work but it actually takes curves and breaks them into multiple straight lines of varying lenghth depending on the font. I was just informed that that is not acceptable. I need curved parts of letters to actually be made of a curve.
    The company with the router has made a library of letters and numbers made of lines and curves but we need an easy way to replace the actual text with this new library. Right now we know of no way to do that except letter by letter. Considering there are usually at least around 150 and could be a thousand or thousands, very time consuming. So the font used is no big deal, just need a way to convert.
  5. #5
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    You will want to try this one out, it will use splines instead of lines.
    http://apps.exchange.autodesk.com/AC...autostart=true
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  6. #6
    AutoCAD 2010
    May 2011
    50
    Got it but cannot make it work. Anything special about loading it that I might need to know?
  7. #7
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    When you downloaded it, it should have loaded for you. Then in ACAD you type T2G to start it. You will have to have admin rights (I believe) for it to install.
  8. #8
    AutoCAD 2010
    May 2011
    50
    It says it loaded when I run the app but "t2g" gets "unknown comand" in AC. Must be because because the AuotoCad is not registered. Boss was trying to save $ and found cheap computer with it loaded.
  9. #9
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    I believe it needs .net 3.5 or higher, you may be on 3.0 or less.
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,137
    AutoCAD is not registered? The computer was used and had AutoCAD already preloaded on it and fully activated? By activated I mean the former owner received an authorization code for the program. Any chance you guys are using an illegal copy of AutoCAD?
  1. TEXT command made in MSexcel fail to execute in command line Autocad 2006 and higher
    By ctdlc888 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Sep 2011, 04:05 am
  2. Clicking on previously made "View" has gone back in time in my drawing, made for SSM
    By PhilENG in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2011, 07:12 pm
  3. text above objects
    By succu8us in forum AutoCAD General
    Last Post: 5th Aug 2008, 07:16 am
  4. Adding text to 3D Objects
    By Dan in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Oct 2006, 05:16 am
  5. Linked text/objects
    By DanielB in forum AutoCAD General
    Last Post: 28th Sep 2006, 01:25 pm
