Here are some examples:
Accessing Hyperlinks:
Adding Hyperlinks:Code:(defun c:test1 ( / en ) (if (setq en (car (entsel "\nSelect Object to View Hyperlinks: "))) (vlax-for hyp (vla-get-hyperlinks (vlax-ename->vla-object en)) (print (vla-get-url hyp)) ) ) (princ) ) (vl-load-com) (princ)
Code:(defun c:test2 ( / en fn ) (if (and (setq fn (getfiled "Select a File to Link to" "" "" 16)) (setq en (car (entsel "\nSelect Object to Add Hyperlink: "))) ) (vla-add (vla-get-hyperlinks (vlax-ename->vla-object en)) fn (vl-filename-base fn)) ) (princ) ) (vl-load-com) (princ)
