rock1 Posted September 7, 2012 Share Posted September 7, 2012 locked objects get selected, but nothing acts on them. that is i do see them getting dotted while i selected all objects on other unlocked layers. is there way that locked layers don't get dotted while selection? just like in sketchup? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 7, 2012 Share Posted September 7, 2012 In OPTIONS > Selection Tab > Selection Preview > Visual Effect Settings > Advanced Options ...... as shown in the image sounds like you are hoping for. Quote Link to comment Share on other sites More sharing options...
rock1 Posted September 7, 2012 Author Share Posted September 7, 2012 that's not working. !! how could it be? still no change. restarted my system and autocad twice . however i i hover my mouse over it it doesn't get highlighted and dotted. i wanted that if i select, [i.e with the selection window], it should not get highlighted. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted September 7, 2012 Share Posted September 7, 2012 When I try to select my locked layers in Modelspace geometry, they are neither highlighted nor selectable. They are LOCKED. They show up, because they are not also FROZEN, but they do not highlight to indicate a selection preview. Quote Link to comment Share on other sites More sharing options...
rkent Posted September 7, 2012 Share Posted September 7, 2012 If you use command first, then select they won't be highlighted, if you select first then enter command they will be highlighted. Quote Link to comment Share on other sites More sharing options...
rock1 Posted September 10, 2012 Author Share Posted September 10, 2012 If you use command first, then select they won't be highlighted, if you select first then enter command they will be highlighted. aaah i see. was doing it allway wrong. thanks Quote Link to comment Share on other sites More sharing options...
rock1 Posted August 2, 2015 Author Share Posted August 2, 2015 Replying too late, as my requirement is a little specific. Is there a way they never get highlighted at all even if I select them first? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 2, 2015 Share Posted August 2, 2015 Almost three years later, that is patience. You could turn off HIGHLIGHT. Quote Link to comment Share on other sites More sharing options...
Dana W Posted August 2, 2015 Share Posted August 2, 2015 Options >> Selection tab. Set them like this. There will be no preview highlighting or dashed line preview until an object is selected whether a command is active or not. Quote Link to comment Share on other sites More sharing options...
rock1 Posted August 9, 2015 Author Share Posted August 9, 2015 apologies for the confusion, I have an issue with the objects only on locked layer. Is there a way the objects on locked layer never get highlighted at all even if I select them first? Quote Link to comment Share on other sites More sharing options...
Commandobill Posted August 9, 2015 Share Posted August 9, 2015 Almost three years later, that is patience. You're not kidding! How about changing LAYLOCKFADECTL to a much higher number, then you won't really be able to tell... Quote Link to comment Share on other sites More sharing options...
RobDraw Posted August 9, 2015 Share Posted August 9, 2015 No confusion. It's just not possible. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted August 10, 2015 Share Posted August 10, 2015 apologies for the confusion, I have an issue with the objects only on locked layer. Is there a way the objects on locked layer never get highlighted at all even if I select them first? Might freezing or turning the layer OFF be viable option? Try using the LAYOFF command, then select an object to define the layer you want turned off. Quote Link to comment Share on other sites More sharing options...
