Page 2 of 14 FirstFirst 1 2 3 4 12 ... LastLast
Results 11 to 20 of 140
  1. #11
    AutoCAD 2013
    Nov 2011
    6,051
    Quote Originally Posted by fredericofrg View Post
    Can you recommend some tutorials to do the first exercise?
    Welcome to the forum.
    Anything is easy, once you know how to do it.
    Start here ..............
    http://www.we-r-here.com/cad/tutoria...ex.htm#tutlist
  2. #12
    Full Member
    AutoCAD 2013
    Sep 2012
    United States
    41
    no.
    The professor give me one week more to do this homework.
    can you guys help me.
  3. #13
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I'm having trouble understanding just what you hope to accomplish if you do not even understand the basics of AutoCAD. It seems, from your answers, you were either taught very little, or you did not pay much attention in class.
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Exercise 1.1 Baseplate.
    Make sure you have ORTHOMODE enabled. Use your F8 key to toggle it.
    Prior to starting this exercise make a quick hand sketch of the baseplate and put the dimensions on it. You'll notice that you will have to calculate a couple of the dimensions based upon those that are already given. When you have all the dimensions of every side then you can draw the baseplate in AutoCAD.
    Note: We will be working our way around the baseplate in a clockwise manner.
    Start the LINE command. Pick anywhere in the middle of your screen when you are prompted "LINE Specify first point:" as this object, if I read the dimensions right, is not very big. Now drag your mouse to the right. Look at your command line. AutoCAD prompts "Specify next point or [Undo]:". I want you to type in the distance 2.0 then press ENTER. AutoCAD should draw the line. As AutoCAD continues to prompt you for the next point drag your mouse downward and type the distance 2.0 at the command line. Once again a line should be drawn on your screen. Now drag your mouse to the right and type 2.0 one more time. You should have three lines on your screen. You can continue with this same procedure (drag and type in the distance) until you work your way around to the next to the last line. When prompted for the last line sement you can just type the letter "C" for "Close" and AutoCAD will complete the baseplate.
  5. #15
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    The order in which the lines should be drawn using the method I described previously. AutoCAD continues to prompt the user to "specify the next point" until the command is cancelled or the last response is "Close".
    Here is the sequence that is followed as taken from the AutoCAD Text window:
    Command: <Ortho on>
    Command: LINE Specify first point:
    Specify next point or [Undo]: 2.0 line 1
    Specify next point or [Undo]: 2.0 line 2
    Specify next point or [Close/Undo]: 2.0 line 3
    Specify next point or [Close/Undo]: 2.5 line 4
    Specify next point or [Close/Undo]: 3.0 line 5
    Specify next point or [Close/Undo]: .5 line 6
    Specify next point or [Close/Undo]: 2.5 line 7
    Specify next point or [Close/Undo]: 2.5 line 8
    Specify next point or [Close/Undo]: 1.5 line 9
    Specify next point or [Close/Undo]: c line 10 drawn by AutoCAD automatically
  6. #16
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I have determined that Exercise 1.2 can be done in the same manner as 1.1 was. When you get to the end of line number 7 just type "C" for "Close" and AutoCAD will draw line number 8 for you. See below.
    Command: <Ortho on>
    Command: LINE
    Specify next point or [Undo]: .5 line 1
    Specify next point or [Undo]: .7 line 2
    Specify next point or [Close/Undo]: 1.6 line 3
    Specify next point or [Close/Undo]: .7 line 4
    Specify next point or [Close/Undo]: .9 line 5
    Specify next point or [Close/Undo]: .6 line 6
    Specify next point or [Close/Undo]: 1.2 line 7
    Specify next point or [Close/Undo]: C "C" for Close
    You should now have two exercises done.
  7. #17
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Where in the United States are you located?
    I would recommend that you skip Exercise 1.3 for the moment and move on to Exercise 1.4. You can go back to 1.3 later.
  8. #18
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Explanation of AutoCAD Function Keys (F1 through F11) at the top of your keyboard.
    _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _ _
    F1 - Opens the AutoCAD HELP file
    F2 - Opens the AutoCAD TEXT window in the drawing area
    F3 - Turns running snaps (OSnaps) on and off
    F4 - Turns 3D OSNAP on and off
    F5 - Cycles through the Isoplane Top, Isoplane Right and Isoplane Left crosshairs positions (isometric drawings)
    F6 - Allow/disallow Dynamic UCS
    F7 - Turns the GRID on and off
    F8 - Turns ORTHO mode on and off
    F9 - Turns SNAP on and off
    F10 - Turns POLAR TRACKING on and off
    F11 - Turns OBJECT SNAP TRACKING on and off
    F12 - Dynamic Input
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Buttons on the Task Bar (lower left-hand corner of your screen).
    From left to right they are...
    Infer Constraints
    Snap Mode (F9)
    Grid Display (F7)
    Ortho Mode (F8 )
    Polar Tracking (F10)
    Object Snap (F3)
    3D Object Snap (F4)
    Object Snap Tracking (F11)
    Allow/Disallow Dynamic UCS (F6)
    Dynamic Input (F12)
    Show/Hide Lineweight
    Show/Hide Transparency
    Quick Properties
    Selection Cycling
    In the far left hand corner is where your coordinates are displayed.
    Note the tabs above the Command line. There is always one for MODEL space and two (the default) for paper space LAYOUTS. We draw our objects in model space at FULL size. We do not scale objects in model space like we would if we were drawing them on a drafting board. No matter how big or small the item is draw it FULL size.
  10. #20
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    The Layer Properties Manager. This is where you create all your layers and define their properties. The default AutoCAD template, acad.dwt, opens when you start a new drawing. There is only one defined layer (Layer "0" - color: white) in this template. You can create a custom template file with all your layers predefined. It is a real time saver.
  1. 2013 Problems???
    By idllc in forum MEP
    Last Post: 24th Aug 2012, 04:58 pm
  2. Replies: 0
    Last Post: 21st Aug 2012, 08:40 pm
  3. my drawing is not fitting onto my paper space please help??? begginer
    By antons99 in forum AutoCAD Drawing Management & Output
    Last Post: 11th Oct 2011, 03:10 am
  4. 3D Begginer
    By Sylvia Dant in forum AutoCAD Beginners' Area
    Last Post: 7th May 2006, 10:30 pm
  5. begginer
    By rotrek007 in forum Catch All
    Last Post: 29th Nov 2005, 03:05 pm
