Page 3 of 14 FirstFirst 1 2 3 4 5 13 ... LastLast
Results 21 to 30 of 140
  1. #21
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    The "Ribbon" is found at the top of your screen. It has several tabs with different panels on each tab. This version is for 2D Drafting. There is a different one for 3D Modelling. Above the Ribbon I have elected to show the Menu Bar which has drop-down menus under each heading. In the upper left hand corner is the Quick Access Toolbar (QAT). All these elements can be customized by the user to suit his or her own needs and work style.
  2. #22
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Exercise 1.4 done using the LINE, CIRCLE and OFFSET commands found on the Ribbon.
    The basic shape of the filter plate can be constructed in the same manner as the objects in the first two exercises (drag a line and type a distance).
    This is where you find the commands.
    Why OFFSET? Despite the fact there are probably two or three other, probably faster ways of doing this, I think you are lacking in your knowledge of even the most basic commands let alone more advanced techniques. Maybe someone will be kind enough to create a video for you demonstrating another way of accomplishing the task using Polar Tracking and Object Snap Tracking.
    See post #32 for an explanation of the OFFSET command. It includes an image as well as a sample drawing file to use to practice the technique I have described.
  3. #23
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Exercise 1.5 can be done similar to 1.4 in terms of the linework and one of the two circles. For the second circle (on the right) I would use the MIRROR command and pick the Midpoint of the top line. This means however you will either have to key in the letters MID when asked for a base point in the MIRROR command or pick it if you have your OSNAPS set up with Midpoint enabled.
    Common OSnaps most users enable are Endpoint, Midpoint, Center, Quadrant, Intersection, Perpendicular, and Parallel.
    So for this exercise use the LINE, OFFSET, CIRCLE and MIRROR commands and you should do just fine.
  4. #24
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    What the OSnaps "Settings" dialog box looks like. You can activate it by right-clicking on the Object Snap button in your Task Bar or by typing OSNAP at the command line then pressing ENTER.
  5. #25
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Exercise 1.6 is an easy one. Drag the line enter the distance and use the "Close" option to finish it off where the diagonal line is. Shouldn't take you more than 30 seconds. All you need is ORTHO mode turned on and the LINE command.
    Start where indicated and proceed in a clockwise direction.
    Skip Exercise 1.9 and go directly to 1.11; we'll come back to 1.9 later.
  6. #26
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Exercise 1.11 is going to require that you enable and make use of the Quadrant OSnap. You can actually calculate the length of lines needed on each side to connect the two end circles saving you the time to Trim or Fillet (with a radius of "0").
    I believe the diagram gives the wrong radii for the inner/outer large curves (or "fillets"). Use the FILLET command to create them.
    You'll need to use the COPY command. Just make sure ORTHO mode remains toggled as you copy the circle 2.5 units to the left which can be entered at the command line.
  7. #27
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,879
    Exercise 1.9 (Dorm Room) requires the user to utilize both SNAP and GRID. The extents of the room is defined by the coordinates in the lower left and upper right hand corners of the room. The GRID is set at 0.25 increments so to calculate furniture size and placement you will have to use your math skills. For example, the bed is 10 units by 5 units (10*0.25 and 5*0.25).
    Exercise 1.3 will be a little trickier. You will first have to change the UNITS you are working in from DECIMAL to ARCHITECTURAL via the UNITS command. You will have to also set the PRECISION to 0'-0". From the note below the diagram I am assuming the student is to use Polar Tracking to draw the property line boundary.
    When you finish all the other exercises we can tackle these two problems. But until then you have some work to do. I would like you to post an image of each completed exercise and don't be surprised if I ask for a copy of your drawing file at some point too. Be prepared. Good luck with your assignment.
  8. #28
    Full Member
    AutoCAD 2013
    Sep 2012
    United States
    41
    Thanks ReMark for your help. (you were either taught very little, or you did not pay much attention in class.)
    Just i think don't understand the class because i just learn basic english for 5 months before move to US.
    Can i ask you one thing?
    If yes in the start to the exercise 1.1 Baseplate i need use the command LINE and i need put the first line size? example 2.50 or i need specify one point to the line start and after this where i can put the first and second line size?
    Thanks so much, i just start right now,again ^^ but now i know more things.
  9. #29
    AutoCAD 2013
    Nov 2011
    6,056
    ReMark has given you the commandline input.
    He tells you EXACTLY what to do in POST #14.
    Read the entire post, make the hand sketch before you start drawing
    the lines with the program.
    MAKE SURE YOUR ORTHO IS TURNED ON before you start, just like ReMark says.
    After starting the LINE command and indicating a starting point for it,
    you will indicate the direction in which you would like the line to go by moving your mouse in that direction,
    then you will enter the number (length of the line), and hit ENTER (not TAB). Your first line is now drawn,
    FOLLOW THE COMMANDLINE PROMPTS, for the next line you do not need to restart the LINE command because it is still running.
    Just move your mouse in the direction which you want the next line to go, enter the length of the next line, and hit ENTER again.
    It is hitting the ENTER button which tells the program to go ahead and create the line which you have just defined.
    You will do it after every distance (length) entry, before indicating the information for the next line.
    To complete the last line in the drawing (of a closed shape) you may use the CLOSE option, for which you just enter C at the commandline, then ENTER.
  10. #30
    Full Member
    AutoCAD 2013
    Sep 2012
    United States
    41
    Where in the United States are you located?
    I would recommend that you skip Exercise 1.3 for the moment and move on to Exercise 1.4. You can go back to 1.3 later.
    Bemidji-Minnesota just for 1 year.
    After this i just move to Orlando,FL and start my real major is Visual Effects & Motion Graphics.
  1. 2013 Problems???
    By idllc in forum MEP
    Last Post: 24th Aug 2012, 04:58 pm
  2. Replies: 0
    Last Post: 21st Aug 2012, 08:40 pm
  3. my drawing is not fitting onto my paper space please help??? begginer
    By antons99 in forum AutoCAD Drawing Management & Output
    Last Post: 11th Oct 2011, 03:10 am
  4. 3D Begginer
    By Sylvia Dant in forum AutoCAD Beginners' Area
    Last Post: 7th May 2006, 10:30 pm
  5. begginer
    By rotrek007 in forum Catch All
    Last Post: 29th Nov 2005, 03:05 pm
