Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 32
    Senior Member nod684's Avatar
    nod684's Computer Details
    Windows 7 Home
    Architectural
    AutoCAD 2010
    Jul 2012
    Singapore
    229
    Unhappy Isometric Polygon
    does anyone has a lisp to spare to draw an Isometric Polygons?
    what i do is make an Isometric Circle, Divide the circle into parts, trace the nodes, erase the circle and nodes and there's my polygon.
    "Memories fade but the scars still linger...."
    Full Member Manila Wolf's Avatar
    Construction
    AutoCAD 2009
    Oct 2011
    Philippines
    90
    If I understand correctly, your isometric circle is an ellipse.
    Are your divisions all of equal length?
    If so, the distinguished Lee Mac has an excellent program that will equally segment circles and ellipses (and others) into equal length segments.
    I regularly use this program. I am sure Lee will not mind me directing you to this. Thanks Lee.
    Can be found on Lee's site here: -
    http://lee-mac.com/segmentcurve.html
    Windows 7 Home
    Architectural
    AutoCAD 2010
    Jul 2012
    Singapore
    229
    Quote Originally Posted by Manila Wolf View Post
    Thanks for the reply wolf. Yes...i have it is an ellipse
    what am looking for sana is a lisp that will prompt me for how many sides will the polygon be and input the diameter agad.
    But this helps too. Thanks a lot!
    Senior Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2012
    Feb 2010
    Belgrade, Serbia, Europe
    326
    Maybe, this :
    Code:
    (defun transptiso (pt)
      (list (+ (car (polar (list 0.0 0.0 0.0) (/ pi 6.0) (car pt)))
            (car (polar (list 0.0 0.0 0.0) (* 5.0 (/ pi 6.0)) (cadr pt))) )
            (+ (cadr (polar (list 0.0 0.0 0.0) (/ pi 6.0) (car pt)))
            (cadr (polar (list 0.0 0.0 0.0) (* 5.0 (/ pi 6.0)) (cadr pt))) )
            0.0
    (defun c:isopolygon (/ pol vertlst vertlstn)
      (vl-cmdf "_.ucs" "w")
      (vl-cmdf "_.plan" "")
      (vl-cmdf "_.zoom" "c" "0,0,0" "")
      (vl-cmdf "_.polygon" pause "0,0,0" pause pause)
      (setq pol (entlast))
      (mapcar '(lambda (x) (if (= (car x) 10) (setq vertlst (cons (cdr x) vertlst)))) (entget pol))
      (setq vertlst (reverse vertlst))
      (setq vertlstn (mapcar '(lambda (p) (transptiso p)) vertlst))
      (entmake
        (append
          (list
            '(0 . "LWPOLYLINE")
            '(100 . "AcDbEntity")
            '(100 . "AcDbPolyline")
            (cons 90 (length vertlstn))
            '(70 . 1)
          (mapcar '(lambda (x) (cons 10 x)) vertlstn)
          (list (list 210 0.0 0.0 1.0))
      (entdel pol)
      (vl-cmdf "_.ucs" "p")
    M.R.
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
  5. #5
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,089
    Quote Originally Posted by nod684 View Post
    Sounds easy enough.
    Not sure if what you need is the same as what i have in mind. can you post an image of the desired result?
  6. #6
    Windows 7 Home
    Architectural
    AutoCAD 2010
    Jul 2012
    Singapore
    229
    Hi M.R.
    tried using your routine but i think have some error as the resulting polygon is not Isometric
    pBe, image attached
  7. #7
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2012
    Feb 2010
    326
    Turn polar tracking to 45 degrees, and while executing routine make 6 sided polygon with "Inscribed" option with angle 135 degree... You'll get what you posted - conventional way... My code does draw isometric polygon - see my attached jpg...
    M.R.
    M.R. on YouTube
  8. #8
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,089
    pBe, image attached
    Conventional way means the isocircles are existing?
  9. #9
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    I don't think 'isometric' is the correct term to describe the result that the OP is looking to obtain, which may be misleading those who are attempting to provide a solution; that said, I'm not sure that I completely understand the desired result.
    Lee Mac Programming
    Just another Swamper
  10. #10
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,089
    Quote Originally Posted by Lee Mac View Post
    Indeed it does shows an odd shape polygon, i attempted to write a code based on the description on the first post, (granting the isocircles are existing)
    Code:
    (defun  c:sample (/ objell sides seg seg2 pts)
      (vl-load-com)
      (setq objell  (car (entsel)))
      (setq sides (getint "\nEnter number of sides"))
      (setq  seg  (/ (vlax-curve-getdistatparam
                  objell
                  (vlax-curve-getendparam objell)
                sides
                ) seg2 0.0
      (repeat sides
        (setq
          pts
           (cons (vlax-curve-getpointatdist objell (+ seg seg2)) pts)
        (setq seg2 (+ seg seg2))
      (command "_Pline" "_non")
      (foreach pt (cons (last pts) pts) (command pt))
      (command)
      (entdel objell)
    My guess is this thread has something to do with the OP's post on another forum. creating isocircles oriented on Top/Left/Right
    http://www.theswamp.org/index.php?topic=42737.0
  1. Replies: 2
    Last Post: 8th Jul 2012, 11:13 pm
  2. Replies: 5
    Last Post: 6th Jul 2012, 04:59 pm
  3. polygon in isometric
    By cytechnician in forum AutoCAD General
    Last Post: 19th Aug 2011, 05:35 am
  4. polygon command
    By cadamrao in forum AutoLISP, Visual LISP & DCL
    Last Post: 28th Jul 2011, 03:30 pm
  5. Point in polygon VBA
    By klpocska in forum .NET, ObjectARX & VBA
    Last Post: 14th Feb 2011, 06:53 am
