Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2008
    Sep 2012
    3
    Default Trouble extruding a cornice profile
    I'm having trouble extruding a profile i have created. Get "Cannot sweep or extrude a self-intersecting curve" error. I have used the overkill command to find any duplicate lines. Any help would be greatly appreciated. Trying to extrude along a straight line.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Does presspull work?
    But I think I would fix this loop.
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Also I dimensioned this thing in inches and metric and the dimensions don't make sense to me (not manufacturable).
    Forum Newbie
    AutoCAD 2008
    Sep 2012
    3
    thank you, i found the lines right after posting the question. Also what do you mean by dimensioned? its is a cornice profile so if it was extruded it would form the finished positive shape; it is to be made by bench running plaster.
  5. #5
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    If I dimension the profile the lines do not come out to measureable, logical values like 1 inch, instead coming out to something like 1.2345678
  1. Trouble Extruding a shape onto a cylinder (cutting).
    By transonik21 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Oct 2011, 07:30 pm
  2. 3 d cornice
    By tanu agarwal in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Sep 2008, 11:05 am
  3. trouble extruding closed polyline
    By New2CADmike in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2007, 08:27 am
  4. Trouble Extruding
    By slipperyer in forum AutoCAD Beginners' Area
    Last Post: 6th Nov 2005, 03:58 am
  5. Extruding Handrail Profile along a 3D path problems
    By Warren in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Aug 2004, 03:33 pm
Tags for this Thread
