PDF, JPEG High resolution exports
srichang
Please tell me the best way to get high resolution PDF and JPEG images from Autocad...everything I do is either Fuzzy ( in JPEG) or gets thick and blotchy ( in PDF):(
There are several PDF printers that you can try, such as CutePDF or PDFCreator. Lately I have used the on-board PDF printer that comes with AutoCAD and that works perfectly.
If your lines get thick on the PDF, it could be the CTB-files fault, if you are using one of those? Or you have too big line weight on your lines?
As for JPG, I have no good idea there. Sorry.
If you want to paste jpg into word etc try WMFOUT it works way better. Pretty sure jpg's are 200 dpi and you can not change, rendering allows dpi changing but not just say web-jpg, you can change Tiff resolution .
