Results 1 to 5 of 5
    Senior Member
    Inventor 2009
    Jan 2012
    Israel
    186
    Default In am assembly, constraints don't work
    I attached the file.
    Even though i placed constraints on the sheet metal part, it still moves and rotates
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    I don't see any parts?
    An assembly without parts is useless.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Senior Member
    Inventor 2009
    Jan 2012
    Israel
    186
    Default Sorry, now attached all the files
    When i press update, the sheet metal part takes it's right place, but i can move it
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Are you using the Move command or are you clicking and dragging on the part to try to move it?
    The Move command temporarily overrides all assembly constraints to allow you to temporarily move a part out of the way.
    That is what the Move and Rotate commands are supposed to do - Move or Rotate.
  5. #5
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Also, I noticed that your sketches are still not constrained and that you are doing too much work.
    You should (almost) never repeat dimensions. Add geometry constraints like equal(=) rather than double dimensions.
    You were also missing tangent constraints.
  1. Hotfix - Assembly constraints fail on folded parts
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 2nd Dec 2010, 11:10 pm
  2. Assembly Orientation, Inconsistant Constraints
    By Laurel in forum Autodesk Inventor
    Last Post: 27th May 2010, 06:30 am
  3. Assembly Constraints Question
    Last Post: 22nd May 2010, 12:45 pm
  4. assembly constraints not valid in dynamic simulation??
    By olive green in forum Autodesk Inventor
    Last Post: 1st Jun 2009, 01:45 pm
  5. keeping constraints of a sub-assembly
    By WagglyFawn in forum Autodesk Inventor
    Last Post: 10th Apr 2008, 12:17 am
