Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 36
    Senior Member Geobuilder's Avatar
    Geobuilder's Computer Details
    Windows 7 Professional
    Intel(R) Corel(TM) i7 860 @ 2.80GHz 2.80 GHz
    8 GB DDR2
    NVIDIA GeForce GTS 250 (Microsoft Corporation - WDDM v1.1)
    22 "
    AutoCAD 2013
    Jan 2010
    Russia, Siberia
    205
    Wink Import coordinates from a text file txt (sdr csv) in AutoCAD
    1. File. You can load a file with the extension txt, sdr and csv
    2. Delimiter. Choosing which is the delimiter data available at expansion halyard txt.
    3. Row selection. If you tick the checkbox, you will be able to choose lines from the downloaded file, remove the check mark if you will download all the data from the file. Unfortunately when manually selecting the lines there is a limit, you can choose any number, but did not download more than 256 lines.
    4. Format. Ability to change data formats, with X being the direction of the North.
    5. The main object. Select the object to be built (drafted) to the coordinates of the file, select an object block, will be invited to choose a name from the list of existing blocks in the drawing.
    6. Secondary objects. May sign numbers, marks and description of each point, if the primary object is selected block, and it contains the attributes, the value can be stored in attributes. In addition to the data taken from the file, you can set new ones:
      1. Number. format input *#*, where * - prefix \ suffix can be omitted # - integer.
      2. Altitude. input format - a real number, if you enter with a sign or -, it will be added or taken away, respectively, from the Altitude of the file.
      3. Description. free format input.
    7. Layer. For each object, you can select a layer from the list below in the drawing or create a new one.
    8. Color. For each object, you can select a color.
    9. The height of the text. Set the height of the text
    • Most of the settings of the program will be saved between sessions of AutoCAD.
    • All constructions are in the origin of the current coordinate system.
    • As decimal separator can serve as a point and a comma.
    Video: example of using Program
    Macro to the button: ^C^C^P (if (not C:Geo_import) (load "Geo_Import_v2_7")); ^ PGeo_import;
    Contact the program: Export the coordinates of objects from AutoCAD
    On this site I not only study AutoCAD but I also practice my English. If you find rough grammatical errors in my messages, please inform me with a personal message.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    Welcome back Geo. Looks like you have been very busy. Thanks for sharing your program.
    Full Member cadplayer's Avatar
    cadplayer's Computer Details
    Windows 7
    Intel Core CPU 3.4 GHz, 64bit system
    16GB RAM
    NVIDIA GeForce GTX 400
    Civil 3D 2012
    May 2011
    30
    very nice tool, congratulations
    PS.: would be nice if it could import blocks from txt-file.
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,089
    Impressive Dialog interface Geo
    Nice
  5. #5
    8 GB DDR2
    22 "
    AutoCAD 2013
    Jan 2010
    Russia, Siberia
    205
    Thanks for your feedback
    Quote Originally Posted by cadplayer View Post
    I do not know in what form a txt file could contain blocks. But the program can insert blocks exist in the drawing, the coordinates of the txt file, and if the block has attributes, it can write other values ​​such as numbers, altitude, description
  6. #6
    8 GB DDR2
    22 "
    AutoCAD 2013
    Jan 2010
    Russia, Siberia
    205
    Quote Originally Posted by pBe View Post
    Nice
    Thanks
    Dialogue was probably the hardest part of the program.
    Pity that DCL dead.
  7. #7
    Windows 7
    16GB RAM
    Civil 3D 2012
    May 2011
    30
    I meaning to load a txt-file and import points not only as point/text object but also as block with attributes. I try it before but I becomes not working right
    Otherwise it´s very great you have done it.
    Quote Originally Posted by Geobuilder View Post
  8. #8
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    You could try my old program:
    http://lee-mac.com/ptmanager.html
    Lee Mac Programming
    Just another Swamper
  9. #9
    Windows 7
    16GB RAM
    Civil 3D 2012
    May 2011
    30
    It´s great Lee, but my pointlist looks like that:
    pnr,x-coor,y-coor,z-coor,code
  10. #10
    8 GB DDR2
    22 "
    AutoCAD 2013
    Jan 2010
    Russia, Siberia
    205
    Watch the video: http://www.youtube.com/watch?v=jPcESomvOLg
    The block is used as an example, post
  1. import coordinates of a 3D model to autocad
    By green77park in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Dec 2011, 11:20 pm
  2. Replies: 2
    Last Post: 11th Sep 2010, 12:22 pm
  3. Export/import drawing file to/from csv(text) file
    By mtjipta in forum AutoCAD Drawing Management & Output
    Last Post: 9th Jan 2010, 04:14 am
  4. Import X,Y Coordinates from Excel into AutoCAD
    By Between the Lines in forum AutoCAD RSS Feeds
    Last Post: 1st Jul 2009, 01:13 am
  5. Import text file?
    By ekdesigner in forum AutoCAD Drawing Management & Output
    Last Post: 19th Sep 2007, 12:08 am
