Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Forum Newbie
    s1222s's Computer Details
    Windows
    Construction
    AutoCAD 2007
    Sep 2012
    Sofia
    8
    Default How to draw breaking on 2 parallel lines
    I am trying to break 2 parallel lines and draw closing lines and intersections.
    I try to use getpoint to make a point somewhere at the line but it is not working.
    does somebody has a solution?
    and following insert of an object.
    parlinesbreak.dwg
    Senior Member
    AutoCAD 2006
    Aug 2009
    109
    Hi,
    Try this.
    Code:
    (defun c:BRK()
      (setq snp (getvar "OSMODE"))
      (setvar "OSMODE" 0)
      (setq ent (entsel "\nSelect line to break"))
      (setq po (cadr ent))
      (setq ent (car ent))
      (setq vlent (vlax-ename->vla-object ent))
      (setq po (vlax-curve-getclosestpointto vlent po))
      (setq po1 (getpoint po "\nSelect next point to break"))
      (setq po1 (vlax-curve-getclosestpointto vlent po1))
      (setq ent1 (car (entsel "\nSelect parallen entity")))
      (setq vlent1 (vlax-ename->vla-object ent1))
      (setq po2 (vlax-curve-getclosestpointto vlent1 po))
      (setq po3 (vlax-curve-getclosestpointto vlent1 po1))
      (command "Break" ent po po1)
      (command "Break" ent1 po2 po3)
      (command "line" po po2 "")
      (command "line" po1 po3 "")
      (setvar "OSMODE" snp)
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,089
    Another:
    Code:
    (defun c:br2 (/ lines pt1 pt2 ol plst)
    ;;;	pBe Sep 2012	;;;
    (vl-load-com)
      (prompt "\nSelect Objects to Break:")
      (cond
        ((and
           (setq plst  nil
    	     lines (ssget ":L" '((0 . "LINE")))
           (= (sslength lines) 2)
           (setq pt1 (getpoint "\nPick first point:"))
           (setq pt2 (getpoint pt1 "\nPick second point:"))
           (repeat (sslength lines)
    	 (setq ol (ssname lines 0))
    	 (setq plst (cons (vlax-curve-getclosestpointto ol pt1) plst)
    	       plst (cons (vlax-curve-getclosestpointto ol pt2) plst)
    	 (command "_break" ol "_non" pt1 "_non" pt2)
    	 (ssdel ol lines)
           (mapcar '(lambda	(j)
    		  (entmakex (list (cons 0 "LINE")
    				  (cons 10 (nth (Car j) plst))
    				  (cons 11 (nth (Cadr j) plst))
    	       '((0 2) (1 3))
    HTH
    Forum Newbie
    Windows
    Construction
    AutoCAD 2007
    Sep 2012
    Sofia
    8
    Default Re:
    Thanks. Its working but not at all.
    That is I am trying to do:
    brklns.dwg
    Part of my code:
    Code:
    (defun c:WR1 ( / aa b c c5 c6 c7 c8 cc3 d l la lb dr wbl)
      (setq bl (getvar "BLIPMODE"))
      (setq cm (getvar "CMDECHO"))
      (setvar "CMDECHO" 0)
      (if (not doorw)
        (setq doorw 0.9)
      (initget 2)
      (setq dr (getdist (strcat "Door with: <" (rtos doorw 2 2) ">")))
      (if dr
        (setq doorw dr)
      ;(setq a1 (cdr (assoc 10 (entget (car (entsel))))))
      (setq aobject (cdr (entget (car (entsel "\nSelect first line: ")))))
      (setq a1 (cdr (assoc 10 (cdr aobject))))
      (setq a2 (cdr (assoc 11 (cdr aobject))))
      (setq bobject (cdr (entget (car (entsel "\nSelect second line: ")))))
      (setq b1 (cdr (assoc 10 (cdr bobject))))
      (setq b2 (cdr (assoc 11 (cdr bobject))))
      (setq _c (getpoint "\nBase point: "))
      (initget 1 "Left Right:")
      (setq d (getkword "\nLeft or Right?"))
    (setq _la (angle a1 a2))
      (setq _lb (angle b1 b2))
      (setq lac (angle a1 _c))
      (setq c1 (polar a1 _la (* (cos (- _la lac)) (distance a1 _c))))
      (setq cd (distance a1 b1))
      (setq lbc (angle b1 (polar _c (+ _lb (* 0.5 pi)) (* (cos (- _lb lbc)) cd))))
      (setq c2 (polar b1 (+ _lb (* 0.5 pi)) (* (cos (- _lb lbc)) cd)))
    That "_c" point is not on the place where I've picked it (base point).
  5. #5
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,089
    With prompt for Door Width:
    Code:
    (vl-load-com)
      (cond
        ((and
           (setq plst  nil
           (setq dr (cond
    	((getdist (strcat "\nEnter Window width"
                     (if dr (strcat " <" (rtos dr) ">: ") ": ")
                                )))(dr))
           (setq pt2 (getpoint pt1 "\nPick second point for direction:"))
           (setq pt2 (polar pt1 (angle pt1 pt2) dr))
    	 (ssdel ol lines)
    	       '((0 2)
    		 (1 3))
    BTW: Welcome to the Forum
    Please do read this Code Posting Guidelines
  6. #6
    Forum Newbie
    Windows
    Construction
    AutoCAD 2007
    Sep 2012
    Sofia
    8
    Great thanks. Its working.
    I see a lot of thinks need to be clarified in autolisp
    But with getpoint is possible to get a point because I thought it was wrong, right.
  7. #7
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,089
    Quote Originally Posted by s1222s View Post
    You are welcome, Glad to help.
    Hope you'll learn from it.
    Please update your post after reading Code Posting Guidelines <---- Linky
    Cheers
  8. #8
    Forum Newbie
    Windows
    Construction
    AutoCAD 2007
    Sep 2012
    Sofia
    8
    Ok. Why do I really need "vlax-curve-getClosestPoint" in that lisp?!
  9. #9
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,780
    Is this what your trying to do, plus lots more if so private email me the add on to do simple house designs is still avaialble can supply details
  10. #10
    Forum Newbie
    Windows
    Construction
    AutoCAD 2007
    Sep 2012
    Sofia
    8
    Yes right that I try to do but main thing I try is to learn autolisp.
    stefan_ss@abv.bg
  1. Breaking a whole lot of lines
    By Silvercloak in forum AutoLISP, Visual LISP & DCL
    Last Post: 2nd Apr 2012, 02:45 pm
  2. Lines at same angles but not parallel?
    By bobsy852 in forum AutoCAD Beginners' Area
    Last Post: 20th May 2010, 10:25 am
  3. rotating two parallel lines
    By James123 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 17th Feb 2010, 12:18 pm
  4. Parallel Lines
    By irwin5338 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 14th Aug 2008, 09:39 pm
  5. breaking the lines
    By vivekgrs in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Jul 2006, 06:04 pm
