muck Posted September 16, 2012 Share Posted September 16, 2012 I lock my viewports in paper space then I start drawing and editing in my viewport. All a suddenly I will noticed that the image is moving. It seems like the view port image moves out of the port. I then have to unlock the viewport and pan the image back in the port. I have noticed that this is worse in 2013 than 2012. What is the problem here? Is it a program flaw? Is there a way to fix this? Thank you, Quote Link to comment Share on other sites More sharing options...
profcad Posted September 16, 2012 Share Posted September 16, 2012 You have an image attached to AutoCAD in Model Space and when you pan and zoom inside a locked view port the image is panning. Is that correct? Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 16, 2012 Share Posted September 16, 2012 Attach the file here that exhibits this behavior. Quote Link to comment Share on other sites More sharing options...
muck Posted September 19, 2012 Author Share Posted September 19, 2012 There is no images in the drawings with this behavior. The AutoCAD port seens to pan on its own. Thank you, Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted September 19, 2012 Share Posted September 19, 2012 Are you using a clipped viewport? Quote Link to comment Share on other sites More sharing options...
