Page 6 of 6 FirstFirst ... 4 5 6
Results 51 to 60 of 60
  1. #51
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,602
    I'm probably not the person you want reviewing your drawings as I tend to be too much of a perfectionist. Maybe another forum member will volunteer to look them over.
  2. #52
    Junior Member
    AutoCAD 2014
    Jan 2014
    11
    Ok.
    Thank you for your reply.
    But sometime it is better to receive the feedback from a perfecionist person.
    So I can try to do it better.
  3. #53
    Junior Member
    AutoCAD 2014
    Jan 2014
    11
    If someone else can help me on that, I will appreciate it.
  4. #54
    Forum Newbie
    AutoCAD 2013
    Jul 2014
    3
    Hello, I am doing the Civil Drafting Plate 3 right now and i have been reading through threads and looking at the screenshots of examples all day today but still am not able to understand how to start this plate I am running out of time and really need to finish this!!! It says the horizontal scale is 1"=60' does that mean when making the grid/chart the station points are gonna be 60' apart instead of 50' ? how do I set it up???? Please help! THe pictures alone were not enough for me to understand!
  5. #55
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,602
    The instructions for setting up the grid are contained within the project PDF.
    You should also go back through this thread and look at the following posts...#32, 35-37, 39 and 49.
  6. #56
    Forum Newbie
    AutoCAD 2013
    Jul 2014
    3
    Wink
    I did actually, multiple times. And it all makes sense to me except how to set up the grid and how to get the points from the curved part of the driveway because I can't do a straight line down at that specific part. In the project booklet it has not a lot of directions and nothing is really explained about the grid. I'm just wondering how I know the dimensions for the grid part..... Between the station points and the contour levels....
  7. #57
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,602
    Set out the stationing along the bottom of the grid. If one inch equals sixty feet how many inches would equal 50 feet? How many inches would equal 100 feet? Stationing is usally laid out in 50 foot increments starting with 0+00 then 0+50, 1+00, 1+50, 2+00, etc. Stationing runs horizontally from left to right.
    Your contour level is in 10 foot increments. These run vertically. One inch will equal 10 feet vertically; two inches vertically would be equivalent to 20 feet. Pick a range of contours that mimics what you see in your plan view (hint: look at the contours your road centerline crosses).
  8. #58
    Luminous Being tzframpton's Avatar
    tzframpton's Computer Details
    HP Zbook
    Multi-disciplinary
    tzframpton's Discipline Details
    BIM Specialist
    Multi-disciplinary
    Full Virtual Design and Construction BIM services for the MEP engineering and construction industries.
    Revit 2018
    Mar 2006
    Dallas, TX - USA
    9,068
    40k is approaching. Any day now.
    Tannar Z. Frampton ™ | Frampton & Associates, Inc.
  9. #59
    Forum Newbie
    AutoCAD 2013
    Jul 2014
    3
    Thank you kindly for your response, I really appreciate it. When I plot the points from the curved part of the driveway how do I get the right position of the point? I know I have to do a curve from where the centerline crosses the contour line and then draw a straight line down from the curve to plot the curved area of the driveway. How do I know how long the curve is and what kind of angle it will be? The unit booklet never explained this and the project booklet does not say a word about this either. So how am I supposed to know????
  10. #60
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,602
    For what you are doing measure from the nearest stationing point, like 1+50, to the point where the contour crosses the centerline of the road. So if your 190 contour falls 38.5 feet beyond station 1+50 plot the point at station 1+88.5 in your profile.
  1. Need help for penn foster civil drafting project
    By HARPAL in forum Student Project Questions
    Last Post: 10th Jun 2016, 12:09 am
  2. penn foster civil plate 1
    By jcoots17 in forum Student Project Questions
    Last Post: 13th Sep 2012, 11:17 am
  3. Penn Foster-Structural Project, Plate 2
    By Rocktamusprime in forum Student Project Questions
    Last Post: 25th May 2012, 03:32 pm
  4. Help on Penn Foster Civil Drafting
    By tck_17 in forum Student Project Questions
    Last Post: 13th May 2012, 09:14 pm
  5. Structural drafting project Plate 2 (penn foster)
    By ANC2008 in forum Student Project Questions
    Last Post: 13th Jul 2011, 11:47 pm
