Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 69
  1. #21
    Full Member
    AutoCAD 2013
    Sep 2012
    46
    I did not intend to draw my house in anything other than full scale But tell me does this mean that if I take part of the house in a layout, click on scale 1:1 then the representation on my screen should be the real world measurement. What happens when I do this is the drawing shrinks away like star trek warp drive. if I have made a cock up then I will have to redraw it. Not so terrible and great to get it correct.
  2. #22
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    If you assign a scale of 1:1 to a viewport then it will display whatever is in it at full size.
    I think you may have some geometry in your drawing that is far, far away in a distance universe and AutoCAD is trying to make it fit in your viewport the best way it knows how.
  3. #23
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    ND: I took a very quick peek at your latest posted drawing and I notice that your viewport is Layout1 is still on layer "y dimensions" and not on the Viewport layer as I instructed.
    I would suggest that you assign a color like "magenta" to your Viewport layer and not something so light that it can barely be seen onscreen. Remember that since the layer is now set to "no print" it doesn't matter if some text or a leader crosses over the viewport frame. No harm...no foul.
  4. #24
    Full Member
    AutoCAD 2013
    Sep 2012
    46
    If I use zoom extents then all I get is the screen the way I expect it to be
    When I use my “existing “ layout” and set it to 1:1 I get this.
    I need to study more. I do not know how to identify what layer a layout is on. I certainly had viewport open and active as I created this layer.
    its getting me down as no doubt it is you. Whereas it is a pleasure to learn new things it is frustrating when simple things seem to be so difficult and numerous references are new to learn. If i knew where my mistake was it would be fine. I don't mind redrawing the lot but not to know why my stuff is not reacting to commands the way it should is frustrating. When i started i saw no reason not to use meters as I can visualize a meter and people talk in meters. So I made one unit a meter. With it as it is I cannot ask some one to look at it. Any how its 6ish her and I have to go back on site to make sure its all OK and see one of the neighbors as there was some sort of an issue today with a pipe.
    All the best and thanks again. You have given me so much.
  5. #25
    Full Member
    AutoCAD 2013
    Sep 2012
    46
    Second image incorrect
  6. #26
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Treat the layout as you would a piece of paper and think of the viewports as windows, windows that allow us to see the objects we created back in model space.
    Your "layout" is not on a layer. The objects that would be in a layout, like our title block and border, notes, callouts and dimensions (if this is the way you want to go) have their own assigned layers.
    Is the last drawing file that you attached to a post the most current one you have?
    What size paper were you going to plot these drawings on?
    What scale did you have in mind. Certainly there are "standard" metric architectural scales that you are familiar with right? Remember it is a house and not a 10 hectare wooded lot. The scale can be larger.
  7. #27
    Full Member
    AutoCAD 2013
    Sep 2012
    46
    Here is the latest autocad. Once uploaded IPlans layer castelnau.dwg will check it.
  8. #28
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    I forgot to ask, did you use one of the AutoCAD metric templates when you started your drawing?
  9. #29
    Full Member
    AutoCAD 2013
    Sep 2012
    46
    That is not the correct file. I will rename it.
  10. #30
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Please read and respond to post #28. It is important.
  1. best way to make this motorbike frame
    By razie1 in forum Autodesk Inventor
    Last Post: 1st Jan 2012, 09:22 pm
  2. How do I make config's of a frame??
    By rdharvey in forum Autodesk Inventor
    Last Post: 26th Oct 2011, 08:08 am
  3. can I make one object 2d wire frame in a viewport?
    By b.muqlueen in forum AutoCAD 3D Modelling & Rendering
    Last Post: 21st Aug 2008, 07:59 pm
  4. Viewport Frame
    By vachelle72 in forum AutoCAD General
    Last Post: 20th Mar 2006, 06:45 pm
