Results 1 to 9 of 9
    Senior Member teknomatika's Avatar
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    Default Question from beginner
    What is failing to not work properly?
    Code:
    ;;writing point with z value
    (defun c:wpz()
    (setvar "PDMODE" 3)
    (setq pt (getpoint "\nPoint:"))
    (setq zv (getdist "\nZ Value:"))
    (setq x (car pt))
    (setq y (cadr pt))
    (command "point" x y zv)
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    maybe so?
    Code:
    (defun c:wpz()
    (setvar "PDMODE" 3)
    (setq x (car pt))
    (setq y (cadr pt))
    (setq cord (list x y zv))
    (command "point" cord)
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    The issue is the way you tried to build the coordinates list:
    Code:
    (defun c:wpz()
     (setvar "PDMODE" 3)
     (setq x (car pt))
     (setq y (cadr pt))
     (command "point" (list x y zv))
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    Quote Originally Posted by MSasu View Post
    Code:
    (defun c:wpz()
     (setvar "PDMODE" 3)
     (setq x (car pt))
     (setq y (cadr pt))
    Tanks, Mircea.
    However, how do I set routine by the size of the point style. For example, to determine their visibility in absolute units?
  5. #5
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Please check the PDSIZE system variable - will need to input a positive value for absolute units (the negative one means percentage of viewport size).
    Regards,
    Mircea
  6. #6
    AutoCAD 2009
    Sep 2010
    Portugal
    247
    Tanks, Mircea.
    Resolved.
  7. #7
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,717
    Not sure I would use getdist
    Code:
     (setq zv (getreal "\nZ Value:"))
    or
     (setq zv (getdist pt "\nZ Value:"))
  8. #8
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    First, I was also tempted to suggest to constrain indication of that distance from insertion point, but later thought that, since OP doesn't gave info about his scenario, then is possible that he/she will pick the said distance in a different part of the drawing.
    Regards,
    Mircea
  9. #9
    Civil 3D 2016
    Dec 2005
    GEELONG AUSTRALIA
    10,717
    A lot of people use GETDIST thinking its as the name implies get a distance when asking for the user to actually enter a value via the keyboard. Its real purpose is to get a distance using mouse style screen input.
  1. Major beginner! Simple question :)
    By circles in forum AutoCAD Beginners' Area
    Last Post: 30th Jul 2012, 04:30 am
  2. Xref Beginner question
    By bezy9530 in forum AutoCAD Beginners' Area
    Last Post: 28th Dec 2010, 05:47 pm
  3. beginner question
    By Lt Dan's legs in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Jul 2010, 03:51 pm
  4. Beginner Question
    By Mezalaja in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jul 2010, 07:26 am
  5. Beginner question
    Last Post: 17th Jun 2010, 07:18 pm
