Results 1 to 5 of 5
    Forum Newbie
    piewie's Computer Details
    XP
    AutoCAD 2006
    Sep 2012
    Canberra, Australia
    1
    Smile Intersecting Tubes
    I have two 3D extruded sections of square tube where the corners are filleted to give a radiused effect. The two tubes intersect each other. This means that the if I look down the centre of one tube I see the section that is intersecting. I want to get rid of this section so when looking down the tube it is clear. I have tried the subtracting and intersecting command but seem unable to get them to work properly. Can anyone help? Please?
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Attach the file here.
    Maybe this will help.
    http://home.pct.edu/~jmather/content...torial%208.pdf
    AutoCAD 2013
    Nov 2011
    6,051
    Welcome to the forum.
    If I read this correctly, I think you are describing a mitered corner of SHS (square hollow section),
    which has radiused corners on the profile?
    If you need to have 2 distinct pieces, so as to display the miter cut in the corner, then you could use the SLICE command.
    Lay out your slicing plane in 2D, as it will be the easiest way. I usually use a slicing OBJECT (and create a circle to be that).
    Or you could just create your Region which describes the end of the Tube Profile, and use the SWEEP command to sweep that
    shape along a RIGHT ANGLE path. In that case you will wind up with a single part, of that same shape as the 2 mitered pieces together.
    Should you need to do a 4 way intersecting miter then you would add another SLICING plane or OBJECT (circles as shown) rotated by 90 degrees from the first
    slicing plane.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,865
    Maybe the two tubes intersect each other like a cross? Go for it Dadgad!
  5. #5
    AutoCAD 2013
    Nov 2011
    6,051
    Like so?
    Added to the images in the previous post.
  1. 3D Tubes
    By Chris_Hebden in forum AutoCAD 3D Modelling & Rendering
    Last Post: 11th Jan 2011, 04:14 pm
  2. Bending Tubes?
    By crevio in forum 3D Modelling
    Last Post: 21st Nov 2009, 04:24 pm
  3. Pipes & Tubes
    By ankurpraja in forum Autodesk Inventor
    Last Post: 16th Sep 2009, 10:56 pm
  4. Vertexes to Tubes/3D
    By cadboi08 in forum 3D Modelling
    Last Post: 26th Mar 2009, 04:30 pm
  5. Joining HHS tubes in 3D
    By robbie in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Nov 2007, 12:30 am
