Results 1 to 10 of 10
    Forum Newbie
    AutoCAD 2011
    Sep 2012
    3
    Default 3D curve like Jagger shape after using "HI" command
    Would like to ask how to solve the Jagger curve issue after using 2D/3D hidden command "HI" in Autocad.
    By the way I am using Autocad 2011 version.
    Below is my attached dwg files:
    Original dwg file "Drawing1-no_hidden.dwg"
    After "HI" command "Drawing2-with_hidden.dwg"
    Appreciate for help. Thanks!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Is that a Mick Jagger curve? LoL
    You have a case of the "jaggies". Try setting the system variable VIEWRES to 5000 (at the command line) and see if it makes any difference.
    Forum Newbie
    AutoCAD 2011
    Sep 2012
    3
    Lol, yup should be "jaggies"
    By the way, it is not working by using "VIEWRES". It seems also happen to Conceptual vitual style. I have no idea now.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    What was VIEWRES set to initially? Did you force a REGEN?
    What is FACETRES set to?
  5. #5
    Forum Newbie
    AutoCAD 2011
    Sep 2012
    3
    VIEWRES set to 1 initially and force to REGEN but the jaggies still there..
    The FACETRES initially set to 0.5. Thanks in advance
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    First, turn off the Grid.
    Second, explode the block and try viewing it again.
    Looks like you have a 3Dsolid there.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Your solid. Ignore the faint white line, it is my crosshairs.
    Gotta run. Catch you later.
  8. #8
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by jjlew_jjlew View Post
    Viewres=1? set it to at least 2000
    set facetres to 10 and regen if needed.
    http://www.cadtutor.net/forum/showth...-working-in-3D
  9. #9
    AutoCAD 2013
    Nov 2011
    6,056
    I had assumed that it was a 3D Solid, as the original post refers to using the HIDE command, no?
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    No. Try to recall how many people have done what they thought to be a 3D drawing only to tell us they created a wireframe out of mere lines (no use of Extrude, Sweep or Press/Pull).
  1. "echo" of the "base" command
    By Sittingbull in forum AutoLISP, Visual LISP & DCL
    Last Post: 20th Feb 2011, 02:15 pm
  2. (command "dim" "DIMLDRBLK" "" |) is not working
    By bijoyvm in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Oct 2010, 12:15 pm
  3. "select shape file" & TgCad.shx
    By astral_realm in forum AutoCAD Beginners' Area
    Last Post: 15th Nov 2009, 10:25 pm
  4. Replies: 0
    Last Post: 9th Feb 2007, 06:26 am
  5. can you "bind" shape files?
    By dbroada in forum AutoCAD Drawing Management & Output
    Last Post: 5th Dec 2006, 11:09 am
