Results 1 to 6 of 6
Thread: New linetype
    Full Member
    AutoCAD 2012
    Sep 2012
    75
    Default New linetype
    Hi,
    I need a line to show a fence and it should be a line with a / poking out on one side like -/-/- but the lines in between longer and the side lines just on one side...
    Any ideas of how to make one like that or where I can find one?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,137
    AutoCAD 2012? One option would be to use two commands found under Express Tools called Make Shape and Make Linetype. Need more options see this link.
    http://www.cadtutor.net/forum/showth...ustom+linetype
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,007
    Please check if the first definition from this previous thread is what you were loking for - it may require a little adjustment since use a double slash.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Full Member
    AutoCAD 2012
    Sep 2012
    75
    Yes I have AutoCAD 2012 and I have tried the option of edit the acad.lin file, but I coulden't make it work properly... Also not sure how to make this line look like the company want, with a little slash, 45 degrees, on just one side of the line...
  5. #5
    Full Member
    AutoCAD 2012
    Sep 2012
    75
    Thanks MSasu, that link helped! I sort of made it look like they ask Hurray!
  6. #6
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,007
    Glad to hear that your problem is now solved!
    Regards,
    Mircea
  1. LineType help
    By Proctor in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 26th Jan 2012, 10:18 pm
  2. Replies: 4
    Last Post: 18th Jan 2011, 12:06 am
  3. Linetype
    By Happy55 in forum AutoCAD Beginners' Area
    Last Post: 24th Feb 2009, 10:38 pm
  4. Linetype and Linetype Scale!
    By Penfold in forum AutoCAD Drawing Management & Output
    Last Post: 29th Oct 2007, 11:45 pm
  5. More Linetype Q's
    By samla02 in forum AutoCAD Drawing Management & Output
    Last Post: 22nd Jul 2007, 03:29 pm
