Page 1 of 2 1 2 LastLast
Results 1 to 10 of 11
    Forum Newbie PGuatney's Avatar
    PGuatney's Computer Details
    Windows 7 Professional
    Dell T3500
    Intel XENON
    6.0 GB
    NVIDIA Quadro 4000
    Manufacture
    PGuatney's Discipline Details
    Design Engineer, Dewey Iron Works
    Manufacture
    Heavy Equipment, Pump testing Equipment.
    Mechanical 2013
    Aug 2011
    Dewey, Oklahoma
    8
    Default Erratic lines in FLATSHOT command acad 2013
    I produce a lot of "Exploded View" style drawings for our equipment for assembly drawings and Operators Manuals. I model everything in 3D, set the perspective view, adjust the view I like, then use the Flatshot command to make 2D lines and arcs verions of the view to put into paperspace. Then item bubbles, notes, whatever. as of the last week, my flatshots, if they include a hex bolt head in the view, the arcs on the faces of the flats will be really stretched and skewed decidley toward the vanishing point in the completion of the Flatshot command. It does not happen on other arcs that may be in the model, seems to be exclusive with the hex. I doesn't happen if I do not make the view pespective but leave it "Parallell".
    Any suggestions?
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,131
    Don't use PERSPECTIVE.
    Yeah, I know, I prefer how it looks too.
    Turn off and FREEZE the layer with the bolts?
    You can do it with SOLPROF, like in the image.
    I seem to recall SEANT posting about this known issue with FLATSHOT functionality.
    I've seen some strange results when used on off axis cylindrical solids in PARALLEL too.
    Dell T3500
    Intel XENON
    6.0 GB
    NVIDIA Quadro 4000
    Manufacture
    Manufacture
    Mechanical 2013
    Aug 2011
    Dewey, Oklahoma
    8
    OK. well you can't teach an old dog......well anything. I have used the SolProf command. Hate it. Hate it like I hated MicroStation 10 years ago. Hate it like the using "LOL" instead of having the courage to just laugh. Hate it like Going to Wal Mart, hate it like hearing a Vanilla Ice song come across the radio.......on and on. My hate can be everlasting.
    I have done this flatshot business many times in ACAD 2010. Does anybody know if this is a problem exclusive to release 13? If so, what is Autodesk doing to fix it? I have not contacted Autodesk for a solution. I have loaded release 13 onto my laptop as well, for work at home, does the same thing. That leads me to believe that the problem does not exist with my individual copy of 2013. Could the problem be associated with the way I construct the 3d model? However, I am seeing the erracic arcs in areas other than just hex nuts and bolts. I really wish I could wrap my mind around all the requirements to be met to use the SolProf command, but it is too cumbersome and therefore not a solution for me. I will continue working with solprof, but haven"t found a good description on how to use it. Flatshot ....used to work.....just swell.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,023
    Did you install Service Pack 1.1 for 2013?
  5. #5
    Dell T3500
    Intel XENON
    6.0 GB
    NVIDIA Quadro 4000
    Manufacture
    Manufacture
    Mechanical 2013
    Aug 2011
    Dewey, Oklahoma
    8
    Not sure that I have. I installed the thumb drive software that I received from Autodesk. That was about a month ago. I had hoped it was the latest. I will search out the service pack and install it. Good idea. Is 1.1 the most current service pack? How do I get informed when there is a new service pack?
  6. #6
    AutoCAD 2012
    Nov 2011
    3,131
    Quote Originally Posted by PGuatney View Post
    Have you played with the VIEWBASE functionality yet?
    If not you should, as you will more than likely really HATE it.
    Much to recommend it actually for some things, but no PERSPECTIVE.
    How about doing it as shown in the image?
    When I am doing erection drawings I use the actual model in the display.
    Although I use a PARALLEL view.
    If you go that way you can use PERSPECTIVE all you want.
  7. #7
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,092
    Flatshot has had issues as far back as I can remember. I get similar results in 2011 AutoCAD on occasion. I prefer SOLVIEW/SOLDRAW over SOLPROF usually or I just live with the Flatshot problems. Sectionplane is the best results IMHO, but sometimes it is a pain as well.
    Mechanical Service Packs I believe service pack 1 is the latest for Mechanical.
    This was a .sat, are the bolts .sat also?
    Attachment 37960
  8. #8
    Full Member
    AutoCAD 2012
    Oct 2012
    53
    I usually just make it in paperspace and turn the objects until it looks good (if hidden lines aren't needed)then and ballon and create a bom there, if they need all out work instructions I just save the sheet as a jpeg and write it up in word
    but viewbase is a great addition, easier than solview
  9. #9
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,483
    I've actually never had any issues with FLATSHOT, whether it be perspective or orthographic view type. This is new to me.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  10. #10
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    4 GB RAM
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,092
    Quote Originally Posted by StykFacE View Post
    Try it with .sat (ACIS) file. The handle I show was from McMaster Carr. FLATSHOT has been buggy since it first came out. The results used to give wrong measurements, not much, but enough to mess up machined parts in most cases. Most problems are mostly unnoticeable, so I use it sometimes. Biggest problem, still unresolved since it first was available, is duplicate lines, need to run OVERKILL on the FLATSHOT blocks and more times than not, the OVERKILL will not run on FLATSHOT blocks in the Block Editor.
    Solview/Soldraw still gives best results.
    Viewbase is too restrictive for my taste, even if I had that option.
  1. ACAD 2013 - Cannot Copy in Feet, Only Inches
    By KLong in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 24th Aug 2012, 04:13 pm
  2. Drawing With Constrints Tutorials ACAD 2013
    By DECHAL in forum AutoCAD General
    Last Post: 16th Apr 2012, 12:05 pm
  3. Acad 2013
    By RyanAtNelco in forum AutoCAD General
    Last Post: 12th Apr 2012, 08:04 pm
  4. 2010 MEP Piping & The Flatshot Command
    By Kremer in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Dec 2009, 04:58 pm
  5. Flatshot command does not show tangential edges
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 19th Oct 2006, 12:00 am
