Results 1 to 5 of 5
    Forum Newbie
    not specified
    May 2006
    3
    Default Dimension Lines Wont work!!
    I am a first time user of CAD and I really don't know what I am doing wrong - HELP!! I am using (or trying to use) CAD 2006
    When I try to dimension something it appears as a horizontal line from each point, joined by a perpendicular line - but no measurement - where did the text go?!?!
    Super Member profcad's Avatar
    profcad's Computer Details
    Windows 7 Ultimate
    Dell
    Dual - Six-Core Xeon
    32GB
    NVIDA GeForce GTX980TI
    DUAL 24" WIDESCREEN
    Education
    profcad's Discipline Details
    Professor Of CAD
    Education
    AutoCAD Revit Inventor Soldiworks
    Revit 2018
    Dec 2005
    Oklahoma City, OK
    856
    There could be two problems.
    1) You don't have your dimension scale large enough. If you are doing architecture then your scale should be 48 for 1/4"= 1' or 96 for 1/8"=1'
    Type DDIM on the command line. This will load the dimension style manager.
    Click on the Modify button.
    Click on the FIT Tab.
    Set the overall scale factor.
    2) The other problem could be the text height of the text style.
    Click on the Text Tab.
    To the right of the text style name is a button with the 3 dots.
    This will load the style command to modify text style.
    Set the height to 0 (Zero).
    Close the dialog boxes.
    Let us know if this doesn't work.
    John Helton
    Professor of CAD
    Oklahoma City Community College
    Oklahoma City, OK
    Forum Newbie
    not specified
    May 2006
    3
    Default Thanks a mill
    Thanks for the quick reply - I will try it
    Forum Newbie
    not specified
    May 2006
    3
    Default IT WORKED!!
    Thanks its worked - I have actual writing
    - ok-
    I am going to sound like the super hero of all the dim people on the planet - but would you know what the ideal scale is for working with the metric system- I set it to 100 hoping to get 1:100 - but the text is tiny -
    if I just make the text bigger will it cause problems when I print to different scales - from working to 1:100 then printing to 1:200?
  5. #5
    Senior Member Ako's Avatar
    AutoCAD 2007
    Mar 2006
    Warrington UK
    309
    First things first. You should not be working (Drawing?) to a scale. Next, it depends upon how you are printing. If you are printing from model space you need to set your dimscale at the inverse of the scale you are printing at. If you are dimensioning through a viewport then you set your dimscale at 0 and it will take care of the scale in each viewport itself. Lastly if you are dimensioning in paper space you just set the dimscale to 1 and print full size. The main consideration in all these methods is that you set the dimension variables to the size you want them on the paper you are printing on.
    Dave
