Page 1 of 2 1 2 LastLast
Results 1 to 10 of 12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Default Things you should know about Viewports.
    The following information is about Layout Viewports also known as "floating" viewports which are different than Model Viewports also known as "tiled" viewports.
    Viewports are windows created in a paper space layout that allow the user to see the objects that were created back in model space.
    Viewports can be created using the MVIEW command.
    Viewports can be resized with their grips.
    Viewports can be moved, copied, rotated (see VPROTATEASSOC below), aligned and even deleted.
    Viewports are assigned a scale not the objects back in model space. Objects in model space should be drawn at FULL size.
    Each viewport can be assigned its own scale. Therefore it is possible to have six viewports and each can have a different scale.
    Double click inside a viewport to access model space. Double click outside a viewport to return to paper space. (Thanks Dadgad)
    It's a good idea to put viewports on their own layer and set the layer to "no print" in the Layer Properties Manager.
    Once you have your viewport set up the way you want it is a good idea to have the display locked. This can be done in a couple of different ways. One way is to do it via the Properties palette. The other way is to highlight the viewport frame then right click and change "Display locked" from "No" to "Yes". Doing this will prevent accidentally changing the viewport scale when moving between paper space and model space.
    Question: How does one pan in a locked viewport? Answer: You can grip edit the viewport effectively panning without unlocking it. (Thanks RobDraw)
    It is possible to freeze layers in individual viewports via the Layer Properties Manager and the VP Freeze column.
    Cycle between viewports by pressing Ctrl+R repeatedly until you reach the viewport you want.
    Viewports do not necessarily have to be rectangular; they can be odd shaped (polygonal) or even circular. Do this via the MVIEW command. Use either the Object or Polygonal option.
    The number of active viewports in a paperspace layout is controlled by the system variable MAXACTVP (maximum active viewports). The default setting is 16. The maximum value is 64.
    Viewports are ideally suited to displaying multiple views of 3D objects.
    Viewports can have their own visual style independent of not only each other but of model space too.
    Viewport controls were introduced in AutoCAD 2012 and appear in the upper left-hand corner of a viewport. This feature makes it easy to change the view or the visual style of an individual viewport. (Thanks Dadgad)
    Viewport Controls can be enabled/disabled via the system variable VPCONTROL at the command line.
    Viewport scale can be assigned/changed via the Viewports Toolbar, Properties palette, Quick Properties or by way of the scale list that appears in lower right-hand corner of one's screen on the Taskbar after clicking on the viewport frame. This link contains images of some of these options.
    http://www.cadtutor.net/forum/showth...ight=viewports
    From AutoCAD Help:
    VPROTATEASSOC
    Controls whether the view within a viewport is rotated with the viewport when the viewport is rotated.
    0 When a viewport is rotated, the view inside is not rotated.
    1 When a viewport is rotated, the view inside is rotated to match the rotation of the viewport.
    Note: After rotating a viewport, VPROTATEASSOC is set to 0 for a new viewport created in the same layout.
    Senior Member TKall's Avatar
    TKall's Computer Details
    Windows 7
    Dell Precision 6600
    i-7 2860 Quad Core
    32 GB
    Quadro 4000M
    512 GB SSD
    500 GB 7200 RPM
    Environmental
    TKall's Discipline Details
    Manufacturing, engineering
    Environmental
    We manufacture advanced onsite wastewater treatment systems
    AutoCAD 2013
    Nov 2012
    Montana, USA
    116
    I want two viewports with, for instance, Layer 1 ON in Viewport 1 and Layer 1 OFF in Viewport 2. BTW...it is snowing a blizzard here.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    And that's why there is a VPFreeze column in your Layer Properties Manager.
    As long as it isn't snowing when I am in Montana in July I don't care. You guys can have all the snow for now. Less for us in Connecticut to shovel if most of it falls in Montana.
    Windows 7
    Dell Precision 6600
    i-7 2860 Quad Core
    32 GB
    Quadro 4000M
    512 GB SSD
    500 GB 7200 RPM
    Environmental
    Environmental
    AutoCAD 2013
    Nov 2012
    Montana, USA
    116
    Oh...It was way over on the left. Thanks Mark. And, of course(we hope) it is going to snow in Yellowstone in July, that will help keep the fires down. We have had awful fire seasons recently. And with all the beetle-kill, this year could be bad.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    You're entirely welcomed.
    If I drink lots of water on the flight out and there is a fire maybe I can "p" on it.
  6. #6
    Super Member PotGuy's Avatar
    PotGuy's Computer Details
    Windows 7 Premium
    Structural
    PotGuy's Discipline Details
    Temporary Works
    Structural
    (Trainee) CAD Techie/Draftsman
    Revit 2017
    Oct 2012
    London
    728
    Have you mentioned about being able to set up viewport that doesn't have to be square?
    This space changes a lot. Normally dependant on mood.
    Smilies are abundant in my posts.
    There's no crying in CAD but there sure is a lot of whining not to mention gnashing of teeth, pulling of hair and cursing - ReMark
    There is no crying in CAD. Only mouse slamming and keyboard smashing - RobDraw
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    Quote Originally Posted by PotGuy View Post
    Yes I did. Perhaps you missed the word "polygonal"?
  8. #8
    Windows 7 Premium
    Structural
    Temporary Works
    Structural
    Revit 2017
    Oct 2012
    London
    728
    Yes, I did. Sorry!
  9. #9
    Full Member
    Architecture 2010
    Oct 2012
    27
    Great on viewports.
    It took me about 03 months to learn viewports and layouts and scaling and that staff on my on.
    Had you done this earlier, could have cut the time by 2/3
  10. #10
    Senior Member Fire_col's Avatar
    Fire_col's Computer Details
    Windows 7
    Construction
    Fire_col's Discipline Details
    Contracts/Design Engineer
    Construction
    AutoCAD 2013
    Feb 2010
    Nottingham/Derby UK
    238
    Thanks for this ReMark, as always you have just the answer I'm looking for!
    If you don't say what you mean, you won't mean what you say.
    Yeah how d'you like them apples?
  1. Replies: 10
    Last Post: 19th Mar 2013, 11:22 am
  2. Layout with Multiple Viewports to DWG with the Viewports 'Flattened' Out
    By tkrejci in forum AutoCAD Drawing Management & Output
    Last Post: 23rd Aug 2011, 08:45 pm
  3. Need Help with 3 things...
    By Mason Dixon in forum AutoCAD 3D Modelling & Rendering
    Last Post: 4th Jun 2010, 07:57 pm
  4. 2 things...can anyone help
    By doboy in forum AutoCAD General
    Last Post: 15th Nov 2003, 11:40 pm
Tags for this Thread
