RMateus Posted September 26, 2012 Share Posted September 26, 2012 Dear friends. I needed a lisp to read a excel file with 3 columns: a name, a North coordinate and a East coordinate, and put into autocad the texts in the respective coordinates but with the insertion point in the mid of the text. Thanks. Quote Link to comment Share on other sites More sharing options...
pitcher8811 Posted September 26, 2012 Share Posted September 26, 2012 Are you looking for a lisp that will plot survey points with a name? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 27, 2012 Share Posted September 27, 2012 Simplest way is to export a CSV from excel there are heaps of example lisp's to bring a csv into Autocad. I am pretty sure if you search here you will find exactly what you want or something very close easy to change. Quote Link to comment Share on other sites More sharing options...
BearDyugin Posted September 27, 2012 Share Posted September 27, 2012 For example, how can I solve the task with my program [video=youtube;xupZ6QB_-Xo] Quote Link to comment Share on other sites More sharing options...
pitcher8811 Posted September 27, 2012 Share Posted September 27, 2012 I think the easiest way would be to create an attributed block using fields and have a script file generated in Excel. There is a very good explanation of this here: http://www.lazydrafter.com/autocad-tips/writing-autocad-scripts-with-excel If you will be doing this a lot, I have an excel macro that will automate all of the excel tasks and send the command to either AutoCAD or AutoCAD LT. Lee Mac also has something for this I think. Quote Link to comment Share on other sites More sharing options...
aryanarch Posted April 10, 2018 Share Posted April 10, 2018 dose there is a lisp to import data from excel to create lines in autocad i have excel data which contain three column {(x,y,z)of the base point , (distance) , (Angle of line)} Quote Link to comment Share on other sites More sharing options...
BIGAL Posted April 11, 2018 Share Posted April 11, 2018 If you look at the line command all can be done in excel you would make a column as suggested next note though there is a space after the angle to start a new line. In example just copy the G column for all your lines in one go. line pt @dist line 0,0 @20 line 10,10 @45 line 20,20 @56 Quote Link to comment Share on other sites More sharing options...
aryanarch Posted April 11, 2018 Share Posted April 11, 2018 wow thank you very much it is useful Quote Link to comment Share on other sites More sharing options...
