Results 1 to 7 of 7
    Junior Member
    Revit MEP 2012
    Sep 2012
    11
    Default How do I add a grip and a flip parameter to an annotation?
    How would one go about adding a grip and/or flip parameter to an annotation?
    Senior Member Lee Roy's Avatar
    Lee Roy's Computer Details
    Windows 7 Professional 64-bit
    HP Z400
    Intel Xeon W 3565 @ 3.2GHz
    16GB
    ATI FirePro V5900
    OCZ Vertex 4 - 256GB - Sata III - SSD
    Seagate Barracuda 1TB 7200rpm
    Dual - HP Compaq LA2405wg
    Multi-disciplinary
    Lee Roy's Discipline Details
    CAD/BIM Manager
    Multi-disciplinary
    Architectural, Mechanical, Plumbing, Electrical...JOAT
    Revit 2014
    Apr 2011
    Visalia, CA
    417
    I don't know that you can.
    More detail on the family you're trying to build?
    Typically, you would add the annotation to an object family, and you would put the flip control on the object family which would flip the annotation as well.
    "The thing about quotes on the internet is that you cannot confirm their validity." - Abraham Lincoln
    I -edit- a lot, sorry.
    The rotary engine is the most efficient way of converting fuel to noise ever invented.
    If my post sounds offensive, but can be meant in a non-offensive manner...I meant the latter.
    Junior Member
    Revit MEP 2012
    Sep 2012
    11
    I am trying to built an annotation that is able to be moved forward away from the wall and out left and right yet keep the actual solid geometry in the same place. So flipping it will give it the left right capability.
    Junior Member
    Revit MEP 2012
    Sep 2012
    11
    and griping it will give it full movement to go any way the engineer wants.
  5. #5
    HP Z400
    16GB
    ATI FirePro V5900
    Multi-disciplinary
    CAD/BIM Manager
    Multi-disciplinary
    Revit 2014
    Apr 2011
    Visalia, CA
    417
    Try a symbol with a Field? You can put a symbol anywhere you want.
  6. #6
    Junior Member
    Revit MEP 2012
    Sep 2012
    11
    what do you mean by a field?
  7. #7
    HP Z400
    16GB
    ATI FirePro V5900
    Multi-disciplinary
    CAD/BIM Manager
    Multi-disciplinary
    Revit 2014
    Apr 2011
    Visalia, CA
    417
    I'm sorry, a Label.
    Please feel free to PM me and remind me to check the thread, lol.
  1. Add an Item to flip parameter?
    By Lt Dan's legs in forum AutoLISP, Visual LISP & DCL
    Last Post: 26th Aug 2011, 04:21 pm
  2. Flip Parameter
    By YZ in forum AutoCAD Drawing Management & Output
    Last Post: 15th Mar 2010, 11:54 pm
  3. Flip Back and Forth
    By TimZilla in forum AutoCAD Beginners' Area
    Last Post: 15th Jun 2008, 04:08 pm
  4. dynamic block: bifold doors W/ flip parameter woes...
    By hazardman in forum AutoCAD General
    Last Post: 30th Aug 2007, 01:36 am
