KarolR Posted September 29, 2012 Share Posted September 29, 2012 I projected a spiral onto a plane, and there are many redundant segments. I drew another line, with coincident constraints to a part of this huge spline and tried to trim the rest of the spline, but it gave me errors. How can i explode the spline, like in Autocad Quote Link to comment Share on other sites More sharing options...
JD Mather Posted September 29, 2012 Share Posted September 29, 2012 Why not create as 2D sketch rather than projecting? Attach the file here. Quote Link to comment Share on other sites More sharing options...
KarolR Posted September 29, 2012 Author Share Posted September 29, 2012 what do you mean as 2D sketch? you mean to sketch anew? I attached a simpler file, with the projected spline Drum.zip Quote Link to comment Share on other sites More sharing options...
JD Mather Posted October 1, 2012 Share Posted October 1, 2012 Right click on the spline and select Split Entity. Click one or two points to trim at (you might want to create construction geometry first). Delete the rest of the spline after splitting. Quote Link to comment Share on other sites More sharing options...
