"drawing file not valid"
pgw
Ok I see. I will see if they maybe have ended up there, but they should not since I set it to be saved in the other folder.
To move it, you mean the saved files, do you speak about each day now or? :) Move them every day?
Ok, I understand regarding PDF.
  • Replies 23
  • pgw
    12
  • Dadgad
    6
  • ReMark
    3
  • eldon
    3
Posted Images
Good idea!!! I thought that I had set that already, BUT, it obviously did not happen. I definitelly have to change that for sure, thanks for the good, basic advice! :)
This is how you do it in 2012, then you BROWSE to wherever you want it to be saved to set the path.
You also need to set the frequency with which autosaves are created, and this is how it is done in 2012.
