medomessi2010 Posted September 30, 2012 Share Posted September 30, 2012 :cry::cry: hey guys i have the following fatal error when acad2010 is starting right after it starts , FATAL ERROR : unhandled acess violation reading 0xF59cd40 exceptions at ef14df2h plz :cry::cry: i seriously need this for my work pc operation system : windows xp Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 30, 2012 Share Posted September 30, 2012 Did you try shuting down your computer, rebooting and giving AutoCAD another try? I haven't come across this error at the AutoDesk website but that is not a surprise in and of itself. AutoCAD was running OK previous to this so we need to think about what changed recently. Did you install and updates to Windows? Most users allow this to happen automatically figuring Windows knows what it is doing. Quote Link to comment Share on other sites More sharing options...
medomessi2010 Posted September 30, 2012 Author Share Posted September 30, 2012 yeah i know i have check autodesk website and nothing there about the restarting part i have the same setup in 2 computers and both have the same problem its like when the autocad was installing it couldnot install microsoft net framework and then autocad didnt open i manually installed net frame work and tried the program in both computers .. autocad starts and load after it finishes !! the workshop appears and autocad show that error i perviously posted :S:S:S iam v dissapointed ... :S Quote Link to comment Share on other sites More sharing options...
medomessi2010 Posted September 30, 2012 Author Share Posted September 30, 2012 help plz :cry: Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 30, 2012 Share Posted September 30, 2012 (edited) So you have a .NET Framework problem on two computers at the same time. And both computers are using Windows XP? Unfortunately I cannot hang around here all night. If you are having a .NET Framework problem you'll have to reinstall the correct version. However, in some cases, the version of .NET Framework you are running may have to be completely removed first before a reinstall can proceed. Click on the link below for further information. http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Exception-Errors/td-p/3079002 Edited September 30, 2012 by ReMark Quote Link to comment Share on other sites More sharing options...
medomessi2010 Posted September 30, 2012 Author Share Posted September 30, 2012 yeah both got xp and both got the same framework version i tried to uninstall net frame work but it says .. autocad has not been installed correctly so i reinstalled it and it gave me that error Quote Link to comment Share on other sites More sharing options...
medomessi2010 Posted September 30, 2012 Author Share Posted September 30, 2012 sorry it took me long to reply Quote Link to comment Share on other sites More sharing options...
ReMark Posted September 30, 2012 Share Posted September 30, 2012 My last post. There is a specific procedure for uninstalling AutoCAD posted at the AutoDesk website. Find and follow it. Good luck. Quote Link to comment Share on other sites More sharing options...
medomessi2010 Posted September 30, 2012 Author Share Posted September 30, 2012 why i'd uninstall autocad .. it doesnt say it wasnt installed correctly ... it just gives me that freakin' error Quote Link to comment Share on other sites More sharing options...
Tyke Posted October 1, 2012 Share Posted October 1, 2012 Which version of .NET Framework do you have installed? If I remember rightly RenderMann commented on this recently in another post last week. He said .NET Framework 4.5 doesn't work too well with AutoCAD. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted October 1, 2012 Share Posted October 1, 2012 Are you running the program in XP MODE? Good memory Tyke, just a couple days ago to Bill Tillman, this was the last link he posted regarding the issue http://www.theswamp.org/index.php?topic=42385.msg480976#msg480976 Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 1, 2012 Share Posted October 1, 2012 why i'd uninstall autocad .. it doesnt say it wasnt installed correctly ... it just gives me that freakin' error It was this sentence you wrote in post #6: "i tried to uninstall net frame work but it says .. autocad has not been installed correctly" Maybe you suffer from short term memory loss? Quote Link to comment Share on other sites More sharing options...
medomessi2010 Posted October 1, 2012 Author Share Posted October 1, 2012 its version 3.5 its the same version in autocad setup directory so i guess it has to work ? do i have to install framework manually before i install autocad ? do u think ? so i should uninstall autocad , then install frame work ? and then autocad ? i have check everysite .. no one had this prob before me ? XD this is like my lil discovery hahah please help Quote Link to comment Share on other sites More sharing options...
ReMark Posted October 1, 2012 Share Posted October 1, 2012 No. You are not the first person to ever have a problem with .NET Framework. You obviously did not do a thorough search or you would know this. Uninstall AutoCAD. Uninstall .NET Framework per instructions previously given link to. Reinstall .NET Framework. Reinstall AutoCAD. Quote Link to comment Share on other sites More sharing options...
