Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
    Junior Member
    AutoCAD 2013
    Sep 2012
    20
    Default How can I download the "holes" function in AutoCAD 2013 student version?
    I am trying to add holes for screws to go into on my object.
    Does anyone know what I should do?
    If I need a download can you please tell me which one I need.
    Thanks
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,492
    What version of 2013 are you talking about? Is this an Inventor question?
    Junior Member
    AutoCAD 2013
    Sep 2012
    20
    On the top it just says AutoCAD 2013-student verision. Also I am pretty sure it is autodesk
    -Thanks
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,007
    AutoCAD does not have a tool for sizing holes based on fasteners - you will have to model them the old fashion way - Extrude or Revolve and Subtract or Presspull.
    You should be learning one of the next-generation tools like Autodesk Inventor.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  5. #5
    Junior Member
    AutoCAD 2013
    Sep 2012
    20
    Thank you!
    So AutoDesk professional will allow me to make holes with grooves for screws?
  6. #6
    Junior Member
    AutoCAD 2013
    Sep 2012
    20
    Because I got Autodesk inventor fusion and the only options it is giving me for holes are:
    SImple, counter bore, counter sunk, depth, diamter, and angle. It says nothing about fastner type.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,492
    Quote Originally Posted by knattagh View Post
    Thank you!
    No, it is not called AutoCAD Professional. There is AutoCAD and then there is Inventor. Both are AutoDesk programs but that is where the similarity ends. They are two entirely different programs. As previously stated AutoCAD does not have the feature you are looking for however Inventor does.
  8. #8
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,203
    Inventor Fusion is also a completely separate program from Inventor and AutoCAD.
  9. #9
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,007
    Autodesk Inventor Professional will add "cosmetic threads" - simplified bitmap representations.
    If you want true helical cut threads you will need to model them with the Coil command - just like out on the shop floor.
    You can do the same thing in AutoCAD with the Helix and Sweep and Subtract commands.
    http://home.pct.edu/~jmather/content...torial%204.pdf
  10. #10
    Junior Member
    AutoCAD 2013
    Sep 2012
    20
    Thank you all so much for your posts
    I recently got Autodesk inventor 2013 student version and now I have rebuilt my object and am trying to put threaded holes in it.
    Although, the ok button is greyed out. Some other people have had this problem too and they have solved it via forums but I do not understand what they mean. Could you please tell me how I can get the button to not be greyed out.
    Thanks again
  1. 2004---Command line version of cancel? (As opposed to "Esc")
    By ajs in forum AutoCAD Beginners' Area
    Last Post: 18th Nov 2012, 03:53 pm
  2. Replies: 4
    Last Post: 19th Jul 2011, 04:44 pm
  3. Another student with an "Oleson Village" Plat Map question.
    By Grip Grip in forum Student Project Questions
    Last Post: 29th Nov 2010, 12:15 pm
  4. Copying "holes"
    By raj1954 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 17th Jul 2008, 11:01 am
  5. "Americanizing" a non-US version of AutoCAD
    By ppc in forum AutoCAD Drawing Management & Output
    Last Post: 27th Sep 2006, 07:31 pm
