Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
    Junior Member
    AutoCAD 2012
    Sep 2012
    12
    Default Help with drawing
    Hey guys, so I am new to AutoCad and am willingly attempting to learn it by myself!
    A little insider, I work as an assistant in a tech drawing class at NYU. The catch is everyone in the class is working on AutoCad which I have little to no experience in. The job doesn't require me to know this...but, I might aswell for the future!
    I've been working on one of these design's off a book and was wondering if anyone could guide me through a few thing's, I do know a few basic commands like trim, line, circle, array etc..
    Here is the drawing I am trying to duplicate.
    Here is what I came up with on the Geneva cam.
    ^ Above I circled what I am having a problem with. I came seem to get the notch part correct. It say's that the notch is 6.50 x 3.25 and assuming that is L x W that's what I come up with using the line command. I don't how to close it properly with the circle and also it looks a little funky, what am I doing wrong?
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    First, how to add images to your post (without using links that make your posts get moderated...)
    Second, hi
    third, your problem.
    Try the command REGEN first, that updates your display.
    I see two ways to solve your issue, and what is the right one depends on how the assignment looks. Either you use MOVE and move the notch so that it intersects with your circle. Make sure that you have OSNAP (particulary ENDpoint and APParent intersection) on. Snap to the Endpoint of the notch when you are asked for Basepoint and then slowly move your cursor downwards toward the circle and you should see the Apparent Intersection OSnap.
    The other way is to use the EXTEND command and extend the lines to the circle. This makes the lines slightly longer though, so like I said, depending on what the assigment says (what is actually measured), this might be wrong.
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
    Junior Member
    AutoCAD 2012
    Sep 2012
    12
    Hmm well I accidentally added edited in a picture like the first time before I read your comment so it went back to being moderated I guess. I still can't seem to do it. THe apparent intersection osnap doesn't come up :/ I would use extend but this has to be the actual size. 6.50 x 3.25
    8GB
    280 GB
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    I'll try and explain a bit more,
    Start the command Move.
    you will see the prompt Select objects: at the commandline. Highlight your notch and hit enter
    At the prompt Specify base point: select the end-point of the notch. If you don't see the OSNAP type END and hit enter and it should come up.
    At the prompt Specify second point: type APP and hit enter. Now select the line of your notch and then mouse over the circle and the Appenrent Intersection osnap should come up, when it does, just click and it should snap to the correct place.
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,126
    Your drawing doesn't agree with the posted image. The notch you created is tall and narrow while the notch in the diagram is short and wide.
    See post #12 of this thread.
    http://www.cadtutor.net/forum/showth...se-up.../page2
  6. #6
    Super Member CyberAngel's Avatar
    CyberAngel's Computer Details
    Windows XP Pro
    Dell Optiplex 330
    Civil
    CyberAngel's Discipline Details
    Civil Drafter
    Civil
    Civil 3D 2013
    Jul 2006
    Anywhere Else
    977
    Here's a simple way to make your notch. Use the Offset command, give it a distance of 3.25, select the central axis, offset it left, select it again, offset it right. That gives you the sides.
    Draw a horizontal line from the intersection of an offset line (either one) with the circle to the same point on the other line. This is a temporary line. Offset it 3.25 to the top side. That gives you the top. Erase the temporary line.
    You can use Trim or Fillet (radius zero) to finish off the sides of the notch.
    breaking AutoCAD on a regular basis since 1991
  7. #7
    Junior Member
    AutoCAD 2012
    Sep 2012
    12
    Thank's SO much guys. Now I am not sure how to make the curves or archs...
    This is where am I at:
    http://i49.tinypic.com/21nqo8y.png
    Also tiger, I am not getting the option to add pictures from computer when I click insert image:
  8. #8
    Junior Member
    AutoCAD 2012
    Sep 2012
    12
    Hey tiger, it wont let me insert an image straight from my desktop. Only give's me the option to insert an image by a URL. Anyways, so thank you so much guy's I got the notch part down! Now can someone help me with the curve's and archs? Im not sure how to do that...picture's would help TONS! Thank you!!
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,126
    You have the information you need right in the drawing except that the "73" should be a radius and not a diameter. The other two pieces of information you need about both radii as well: 92 and 32.
  10. #10
    Junior Member
    AutoCAD 2012
    Sep 2012
    12
    Yes I figured that out..just a error in the book. How can I make that U shape? I am confused on that part..
  1. Replies: 3
    Last Post: 14th Sep 2011, 05:48 pm
  2. Replies: 4
    Last Post: 9th Sep 2011, 11:08 pm
  3. Replies: 1
    Last Post: 6th Feb 2011, 02:32 am
  4. Copy AutoCAD Drawing with X-Refences without open drawing
    By samcoozy in forum AutoCAD Drawing Management & Output
    Last Post: 5th Jul 2010, 03:27 pm
  5. Creating a new drawing form an existing drawing -AC2002-
    By Michael in forum AutoCAD Beginners' Area
    Last Post: 16th Apr 2003, 07:41 pm
