Results 1 to 5 of 5
    Forum Newbie
    AutoCAD 2013
    Oct 2012
    1
    Default 2d DXF file converted to a format for my cnc
    i have a 2d dxf file (attached) that i need to somehow convert into a 3d file with a material thickness of .75 inches (a peice of wood) so that the cnc can cut it it keeps giving me an error of no thickness in the machine, i dont know what to do, can somebody help me?
    Senior Member
    AutoCAD 2015
    Sep 2010
    New Zealand
    217
    You need to 'Region' all the profiles and 'subtract' out the 'regioned' holes and then you will be able to extrude the 0.75" length and then save as a dxf again.
    Hope this helps
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    Quote Originally Posted by Grant View Post
    'Region' 'subtract' extrude.
    That sounds like a 4 letter word to me - "work".
    Get lazy. Presspull
    Senior Member
    Manufacture
    iainlines's Discipline Details
    Manufacture
    I make boxes n stuff!
    AutoCAD 2013
    Dec 2011
    Smack bang in the middle of England
    264
    Is this a cnc router I assume as you're machining wood? Can you not set your material thickness i your cad/cam software and then assign a depth of cut to each piece of 2D geometry?
    But then I am assuming you're either profiling or cutting at a flat bottomed depth
  5. #5
    Senior Member
    Manufacture
    Manufacture
    AutoCAD 2013
    Dec 2011
    264
    Is your cad/cam anthing like this?
  1. rhino file converted to dxf. model off screen, not aligned to x,y
    By lortech in forum AutoCAD Beginners' Area
    Last Post: 22nd Jul 2010, 12:40 am
  2. Error while opening a DXF file converted from PDF
    By saadicarnot in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 2nd Nov 2009, 11:24 am
  3. Text converted to graphics when file is plotted to PDF
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 13th Sep 2006, 03:03 am
  4. File Format Help EPS - STP
    By TiSwAs in forum AutoCAD Drawing Management & Output
    Last Post: 8th Nov 2004, 09:02 am
