Results 1 to 8 of 8
    Full Member
    rodrigo_sjc_sp's Computer Details
    Windows 7 (32bits) - Version 6.1 - Comp. 7601 SP1
    DELL
    Pentium(R) Dual-Core CPU E5300 @2.6GHz
    2,00 GB
    1440 x 900
    148GB
    LG
    See details...
    rodrigo_sjc_sp's Discipline Details
    Analyst programmer
    See details below.
    Analyst programmer
    AutoCAD 2011
    Oct 2012
    São Paulo - Brazil
    96
    Default Select Polyline with variable ?
    I need select a Polyline with a variable,
    This code is ok!
    (setq selpline (ssget "_x" '((0 . "LWPOLYLINE")(8 . "First"))))
    I need convert to:
    (setq cod "Second")
    (setq selpline (ssget "_x" '((0 . "LWPOLYLINE")(8 . cod))))
    But this code return
    Command: ; error: bad SSGET list value
    I need help to make this code.
    Thanks
    Rodrigo
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,627
    The name of the layer should be string like the first line of code you brought .
    Code:
    (8 . "cod")
    - When aim is being settled in my mind , I have to reach it and get it in hand whatever it costs and wherever it is and will never give up . Tharwat said
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,714
    Lee Mac Programming
    Just another Swamper
    Full Member
    DELL
    2,00 GB
    1440 x 900
    148GB
    LG
    See details...
    Analyst programmer
    See details below.
    Analyst programmer
    AutoCAD 2011
    Oct 2012
    São Paulo - Brazil
    96
    Default thank you!
    thank you ! =)
  5. #5
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,714
    You're welcome!
    Lee Mac Programming
  6. #6
    Full Member
    DELL
    2,00 GB
    1440 x 900
    148GB
    LG
    See details...
    Analyst programmer
    See details below.
    Analyst programmer
    AutoCAD 2011
    Oct 2012
    São Paulo - Brazil
    96
    Default error
    if i use
    (setq valor "X1")
    (setq selpline (ssget "_x" '((0 . "LWPOLYLINE")(8 . "valor"))))
    The lisp does not recognize the value of the variable
    If use variable with "" the lisp recognize VALOR and not X1
    Any help?
  7. #7
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,627
    Quote Originally Posted by rodrigo_sjc_sp View Post
    if i use
    (setq valor "X1")
    Any help?
    Hola .
    It should like this .
    Code:
    (setq valor "X1")
    (setq selpline (ssget "_x" (list '(0 . "LWPOLYLINE")(cons 8 valor))))
  8. #8
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,714
    if i use
    (setq valor "X1")
    Any help?
    Did you read the post I linked to?
    Lee Mac Programming
  1. Select one line of a Polyline
    By guitarguy1685 in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Jul 2011, 09:01 pm
  2. select polyline
    By neunew in forum AutoLISP, Visual LISP & DCL
    Last Post: 24th May 2010, 03:09 pm
  3. select inside of a polyline
    By flopo in forum AutoLISP, Visual LISP & DCL
    Last Post: 3rd Feb 2010, 12:13 pm
  4. select a polyline
    By Huibert in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Oct 2008, 03:33 pm
  5. Select SubEntity in Polyline
    By krugler in forum AutoLISP, Visual LISP & DCL
    Last Post: 19th Apr 2006, 09:51 pm
Tags for this Thread
