Hi Sunny60,
I moved your question to its own thread.
Please explain more about what you're after - what are converting from and to?
Hi Good Morning, I dont understand how to calulate in AutoCAD the Conversion factor. I need to calculate the complete Building Floor and I try the field command in AutoCAD, But I dont know what I should write to conversion factor. Please can you tell me the conversion factor.
Thanks
SUNNY60
Hi Sunny60,
Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
at the moment in one's personal UCS.
Go to PLAN view instead. - Dadgad
Are you calculating the area of a floor plan?
Is the drawing done in metric and you're trying to convert to imperial or vice versa?
Hi Thanks for your responed, Am working on Building and I need to calculate the area with the Field Command from AutoCAD, so I went to Field, Field Category , Objects type, Additional Format and Conversion Factor. I just want to know which conversion factor do I need to st it if want all to be calculate in Sq M for me.
Thank you
Sunny
And what are you converting from?
1000000 square millimeters = 1 square meter
The drawing is in metric
That would make sense based upon your request for square meters.
I don't do metric drawings so I don't know what the normal output is. See my last post.
The Calculation look like That :- 1596398665.50
Typically, if it has not been changed, the output will be in mms, either square or cubic.
The default units for a metric (iso) template are mms.
If you move the decimal point 6 places to the left you will have converted it from square mms to square meters.
Did you draw this in 4D?
well Thank you I will use your last post to calculate the area, and once again thanks.
