Results 1 to 7 of 7
    Forum Newbie
    Architecture 2013
    Oct 2012
    2
    Default Resizing objects after the fact
    I am trying to figure out Architecture 2013.
    I'm having trouble trying to resize objects after the fact. e.g. I layed out a plan approximately and am trying to specify more exact dimensions after the fact.
    e.g. I have a wall object that is 6' long. I need to adjust it to 6'6-3/4".
    Dragging it is too imprecise because it keeps snapping to things I don't want it to snap too. I know I can click the end arrow and type 6 3/4" and have it lengthen that much. But that means I have to keep doing fractional math in my head. Surely there must be a "right" way.
    What I expect is to have some L and W properties somewhere that I can just edit. I'm sure it's in here somewhere?
    What am I doing wrong?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    How about using the Stretch command?
    Why is Snap even being used?
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,135
    Welcome to the forum.
    Open the PROPERTIES, select the WALL you want to adjust and change the length there.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Isn't AA a parametric CAD software?
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  5. #5
    Senior Member
    Architecture 2011
    Dec 2010
    175
    It does have parameters built in, yeah, but to what extent and how effectively I don't know, because I've never needed to use them.
    Parameters do sound a bit overkill for what the OP's trying to do, imho.
    dJE
  6. #6
    Senior Member Bogbadbob658's Avatar
    Bogbadbob658's Computer Details
    Windows 7
    Asus P8P67 LE
    Intel 2nd Generation Coreā„¢ i5-2500
    8GB 1333MHz Dual Channel DDR3 SDRAM
    512MB Nvidia GeForce Quadro FX 580
    1TB Samsung F3 SATA 7200rpm 32MB Cache
    24" Iiyama LCD Monitor - Full HD 1920x1080
    Architecture 2012
    Aug 2007
    Gloucester UK
    252
    Architecture is a bit more complicated. You can't give a wall a length after you have drawn it via the properties box. You have to move it. If you select the end you want to lengthen move it in the direction you want to move then type the increase in the command line it should then be ok and won't snap to any 2D components. If there is another wall nearby(within the cleanup radius) it will automatically snap to it so you may need to change the cleanup radius in the properties box. I assume you know what a cleanup radius is?
  7. #7
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    Quote Originally Posted by Dadgad View Post
    This does work. But like Bogbadbob mentioned, this will more than likely require you move the wall.
    And if you do get in a bind with fractional dimensions, I use the Calculator built inside AutoCAD. You can do math with fractional feet and inches. For instance, if you have a wall length of 13'6-5/8" and you need it to be at 12'4-7/16", then you can easily figure that out using the calculator on the fly.
    There may be another way to do it but usually I do the math in my head anyways.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  1. Know your Zoom Fact(or)s
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 5th Jan 2011, 02:10 pm
  2. resizing
    By awine in forum AutoCAD Beginners' Area
    Last Post: 5th Aug 2009, 10:45 pm
  3. Resizing?
    By TheIntern in forum AutoCAD Beginners' Area
    Last Post: 2nd Aug 2007, 04:57 pm
  4. resizing
    By Michael in forum AutoCAD Beginners' Area
    Last Post: 3rd Apr 2007, 11:29 pm
  5. weird behaviour, in fact none at all
    By hendie in forum Feedback
    Last Post: 19th Nov 2004, 11:14 am
