TFish Posted October 8, 2012 Share Posted October 8, 2012 Good afternoon. But it would be better if I can figure out what has changed/corrupted/reset and/or deleted some of the items on my leader properties. I have attached a screen shot. In the image I have the leader selected, and have right clicked on it to select its properties. In the past, I was able to select the type of head for the leader (closed arrow, dot, box, etc.) from a drop-down. in that Properties menu to the left. Recently, that has gone MIA, and at times, the Properties menu is nothing but a grey box. This is AutoCAD 2007 by the way. Anyone ever experience this? Is there a setting I've inadvertently changed? Doc1.pdf Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 8, 2012 Share Posted October 8, 2012 PICKFIRST = 1 If that doesn't work you need to run a Repair on your installation. Quote Link to comment Share on other sites More sharing options...
TFish Posted October 8, 2012 Author Share Posted October 8, 2012 I'll give it a whirl. Thanks. Quote Link to comment Share on other sites More sharing options...
TFish Posted October 8, 2012 Author Share Posted October 8, 2012 Looks like I need a repair. Quote Link to comment Share on other sites More sharing options...
SLW210 Posted October 8, 2012 Share Posted October 8, 2012 Do you run any registry cleaners? That is often the cause. Hopefully a repair will fix it. Quote Link to comment Share on other sites More sharing options...
TFish Posted October 8, 2012 Author Share Posted October 8, 2012 Actually, yes. Just recently. I will see if the repair has the desired effect. Thank you for your input. Quote Link to comment Share on other sites More sharing options...
