Results 1 to 3 of 3
    Super Member Lt Dan's legs's Avatar
    AutoCAD 2007
    May 2010
    Florida
    574
    Default Block inserting as group
    I have a block that is inserting as a group. When i insert my block then explode it parts of the block are grouped. Does anyone have an inkling as to why this is happening. Also this is a networked file and is not occuring on anyone elses machine.
    Thanks
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,233
    Check the pickstyle variable value to see if that is the difference.
    C:\Program Files\Autodesk\AutoCAD MEP 2011\Help\filesACR\WS1a9193826455f5ffa23ce210c4a30 acaf-4efb.htm
    Rob
    AutoCAD 2007
    May 2010
    Florida
    574
    Problem solved. Thank you for your help
  1. How to center-align a rectangle to a group/block?
    By BWCAD in forum AutoCAD Beginners' Area
    Last Post: 9th Nov 2012, 06:55 am
  2. Insert a block w/o inserting a block?
    By guitarguy1685 in forum AutoLISP, Visual LISP & DCL
    Last Post: 12th Aug 2011, 12:22 am
  3. Get a block out of a group
    By pmxcad in forum AutoLISP, Visual LISP & DCL
    Last Post: 13th Apr 2011, 11:36 pm
  4. Lisp or codes to explode group of entities (gathered by GROUP command)
    By Sweety in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Dec 2010, 03:19 pm
  5. Difference between group and block?
    By Siberian in forum AutoCAD Drawing Management & Output
    Last Post: 25th Jan 2007, 01:33 pm
