Didn't like the answer my brother Kyle suggested at CAD Everything? A custom lisp routine will work. You just have to find one that gives you the results pictured above.
i install sprinkler heads and am trying to find a way to dimension them like the picture but with only a command instead of dimensioning between every single head/ circle manually.heads.jpg
had nothing to do with liking his answer? i didnt know i was restricted to posting the question to only one site? im trying to find the answer anywhere because i dont know enough to find it on my own?
No one said you were restricted to one site.
How about we change the question instead, as Kyle suggested, and ask if anyone knows of a lisp routine that will dimension lines as shown in the posted image? It appears you do not want arrowheads or extension lines just dimensions which shouldn't be a problem. Now the other question is are the lines that you show (from center-to-center of each circle) going to be a part of the drawing to begin with or do they also need to be drawn? The more information you can provide the better the answer, and maybe even the lisp routine, will be. Are we all on the same page now?
Did you ever follow through with Kyle regarding the lisp routine that he posted an image for?
I saved you the trouble and had Kyle send me a copy of the lisp routine he found. It was authored by forum member Tharwat and dated 06.Dec.2011. It is attached to this post as AutoDim.lsp.txt. To use it you will first have to rename it to AutoDim.lsp then load it via the AutoCAD command APPLOAD. To run it type AutoDim at the command line. Note that it works with lines. That means you will have to have a line that goes from center of circle to center of circle. Yes, I know this isn't exactly what you were looking for but maybe you will get lucky and Tharwart will offer up a modified version of the routine if you ask nicely.
AutoDim.lsp.txt
Since you have only three posts (ten required to PM) your options are limited. He was around early today but apparently he passed this thread by. I'll drop him a PM with a link to this thread. Maybe he'll stop by and take a look. Note that Tharwat is not obligated to change his code. If he does so it is only out of the kindness of his heart and his desire to help other forum members like yourself.
A PM has been sent on your behalf to Tharwat. That's the best I can do at the moment.
i understand, i can set something up to pay him for doing it, this will save me tons of time so its worth it. thanks for all the help!
i have another question. when i open up my templates will i have to do this process everytime in order to use the autodim function or is there a way i can make it so it is there every time?
Lisp routines can be loaded automatically if that is what you are asking.
Visit the website of forum member Lee Mac. Start with the link below. Read the first two tutorials under the heading Lisp Tutorials. If you have further questions come back here and post them.
http://lee-mac.com/tutorials.html
