Page 10 of 10 FirstFirst ... 8 9 10
Results 91 to 94 of 94
  1. #91
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    I just pointed you at a lisp routine. Tharwat has done all the grunt work. Gratis too.
  2. #92
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,156
    Quote Originally Posted by ryan osmun View Post
    also if you wanted to touch it up, once you have selected one circle it cannot go back to that circle, if you could make it so that it can go back to ones that have already gone over that would be really good to.
    Maybe you could try restarting the command.
    Here is my final modification for this and it could repeat as much as you want .
    Code:
    (defun c:CirlesAutoDim
           (/ *error* c go p1 gr e ent dimension p2 lst ang)
      (vl-load-com)
    ;;;   Tharwat Al Shoufi  12. 10. 2012 ;;;
    ;;; Create Dimensions between circles ;;;
      (defun *error* (x) (princ "\n *Cancel*") (princ))
      (if (not acdoc)
        (setq acdoc (vla-get-activedocument (vlax-get-acad-object)))
      (setq spc (if (> (vla-get-activespace acdoc) 0)
                  (vla-get-modelspace acdoc)
                  (vla-get-paperspace acdoc)
      (prompt "\n Select start Circle ...")
      (if (setq c (ssget "_+.:S" '((0 . "CIRCLE"))))
          (setq p1 (cdr (assoc 10 (entget (ssname c 0)))))
          (setq go t)
          (setq
            lst (cons (cdr (assoc -1 (entget (ssname c 0)))) lst)
        (princ "\n Nothing selected or not a Circle object ")
      (while (and go (eq 5 (car (setq gr (grread t 15 2)))))
        (redraw)
        (princ
          "\r Move cursor over circles to add dimension entity between them :"
        (if (and (setq e (ssget (cadr gr)))
                 (eq (cdr (assoc 0 (setq ent (entget (ssname e 0)))))
                     "CIRCLE"
                 (not (member (cdr (assoc -1 ent)) lst))
            (setq
              dimension (vla-adddimaligned
                          spc
                          (vlax-3d-point p1)
                          (vlax-3d-point (setq p2 (cdr (assoc 10 ent))))
            (setq ang (angle p1 p2))
            (cond ((and (>= ang (/ pi 2.)) (<= ang (+ pi (/ pi 2.))))
                   (setq ang (+ ang pi))
                  ((= ang pi) (setq ang (- ang pi)))
                  ((> ang 0.0) (setq ang (- ang (+ pi pi))))
            (vla-put-textrotation dimension ang)
            (setq p1 p2)
            (setq lst (cons (cdr (assoc -1 ent)) lst))
            (if (>= (length lst) 3)
              (setq lst (vl-remove (nth 0 (reverse lst)) lst))
      (princ "\n Written by Tharwat Al Shoufi")
    Full Member
    AutoCAD 2012
    Oct 2012
    46
    again thanks a million that is great and will save me a ton of time!
  4. #94
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,156
    Enjoy it Ryan
    Best of luck .
    Tharwat
  1. Scaling and dimensioning question
    By warbeetle in forum AutoCAD Beginners' Area
    Last Post: 21st Oct 2012, 10:51 pm
  2. Quick dimensioning question...
    By Mason Dixon in forum AutoCAD Beginners' Area
    Last Post: 5th Mar 2010, 02:58 pm
  3. command line up arrow question, and grip edit distance question
    By Rebel in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2008, 03:15 pm
  4. Can anyone help? Question about dimensioning...
    By SmagBoy in forum AutoCAD Drawing Management & Output
    Last Post: 19th Aug 2005, 07:02 am
  5. Ordinate Dimensioning Question
    By DREWDIN in forum AutoCAD General
    Last Post: 29th Jul 2004, 08:59 pm
