Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 94
  1. #21
    Full Member
    AutoCAD 2012
    Oct 2012
    46
    i could include the lines if when i used the function it would just show the length of the line and not any arrows or additional lines.
  2. #22
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,124
    Quote Originally Posted by ryan osmun View Post
    Just make a new Dimension style and adjust it as best as you want it to look like and make it current and after that run the code .
  3. #23
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,736
    So your code reads the current dimension style and emulates it?
  4. #24
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,124
    Yes , that's correct .
  5. #25
    Full Member
    AutoCAD 2012
    Oct 2012
    46
    Quote Originally Posted by Tharwat View Post
    im trying to figure this out, i think this should work if i can figure it out.
  6. #26
    Mechanical
    Mechanical
    AutoCAD 2015
    Oct 2009
    6,124
    Simply , just enter the dimension style and put off the extension lines, dim lines and so on .
  7. #27
    Full Member
    AutoCAD 2012
    Oct 2012
    46
    ok so doing it like this would work, but let me ask you. when i dim it normal i dont have a line at all, the line comes up with the dimension. is there any way you could do this with out me drawing the lines?
  8. #28
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,736
    The routine requires the user to select the lines that are being dimensioned. Unfortunately you are not dimensioning lines, per se, but circle-to-circle center points. I have to wonder how accurate this can be in the field or is this for an "as built"? If one "head" is off, for whatever reason, it makes dimensions from it to the adjacent heads inaccurate.
  9. #29
    Full Member
    AutoCAD 2012
    Oct 2012
    46
    it would have to be accurate. im not sure what you mean when you say if one head is off, like if it is placed wrong in the field, everything will be off?
  10. #30
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,736
    That's exactly what I mean. Maybe the tech reads the tape measure incorrectly, or reads the plan wrong and transposes two numbers. Don't tell me it hasn't happened.
  1. Scaling and dimensioning question
    By warbeetle in forum AutoCAD Beginners' Area
    Last Post: 21st Oct 2012, 10:51 pm
  2. Quick dimensioning question...
    By Mason Dixon in forum AutoCAD Beginners' Area
    Last Post: 5th Mar 2010, 02:58 pm
  3. command line up arrow question, and grip edit distance question
    By Rebel in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Jun 2008, 03:15 pm
  4. Can anyone help? Question about dimensioning...
    By SmagBoy in forum AutoCAD Drawing Management & Output
    Last Post: 19th Aug 2005, 07:02 am
  5. Ordinate Dimensioning Question
    By DREWDIN in forum AutoCAD General
    Last Post: 29th Jul 2004, 08:59 pm
