Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
    Full Member satishrajdev's Avatar
    Surveying
    AutoCAD 2007
    Apr 2012
    Aamchi Mumbai, India
    85
    Default Multiple Offsets
    Hi all,
    as i shown in the drawings, i have centerlines and winglines,
    now what i want is from centerline i want to draw winglines at different distances
    (i.e.10m,25m,45m it could be any distance means not ON proper interval)
    and corridor at the end
    Is there any lisp that could solve my prob.
    Thankx a lot in advance
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,986
    An alternative solution is to draw that as multiline after define an apropriate style.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Forum Deity Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draftsman
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,616
    Try this piece of code .
    Code:
    (defun c:Test (/ *error* d e s k)
      (vl-load-com)
    ;;; Tharwat 09. Oct. 2012 ;;;
      (defun *error* (x)
        (princ "\n*Cancel*")
      (if (and (not (tblsearch "LAYER" "SURVEY LIMIT"))
               (not (tblsearch "LAYER" "SURVEY LINES"))
          (alert " One or two layers [SURVEY LIMIT , SURVEY LINES] are not found in the drawing")
          (exit)
      (if (and (setq s (ssget "_+.:S:L" '((0 . "LINE"))))
                 (initget "WINGLINES CORRIDOR")
                 (setq k
                        (cond ((getkword
                                 "\n Choose one [Winglines/Corridor] <Winglines> :"
                              ("Winglines")
        (while
          (setq d (getdist "\n Specify offset distance :"))
             (foreach x (list d (- d))
               (vla-offset
                 (vlax-ename->vla-object (ssname s 0))
                 x
               (vla-put-layer
                 (vlax-ename->vla-object (entlast))
                 (if (eq k "Winglines")
                   "SURVEY LIMIT"
                   "SURVEY LINES"
    Last edited by Tharwat; 9th Oct 2012 at 10:30 am. Reason: name of layers added to alert function
    - When aim is being settled in my mind , I have to reach it and get it in hand whatever it costs and wherever it is and will never give up . Tharwat said
    Surveying
    AutoCAD 2007
    Apr 2012
    85
    OMG......Thanx a lot tharwat
    that is working beautifully...........but still need little correction
    when i m trying to draw corridor, the line which is drawn must have corridor line properties (i.e. Layer-Survey limit, Color-Blue, Line type-dashed)
    but corridor it draws has wingline properties (i.e. Layer-Survey lines, Color-magenta, Line type-conti.)
    other than this it is working fabulously.....This what i was looking for
  5. #5
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,616
    Quote Originally Posted by satishrajdev View Post
    You're welcome .
    It does that , and when you have the prompt of [Winglines/Corridor] , just enter Corridor or the first letter C is enough .
  6. #6
    Surveying
    AutoCAD 2007
    Apr 2012
    85
    i tried that...
    i entered C after that prompt but still magenta line is appearing
    can u tell why it is happening?
    i have modified this routine, which is as follow
    Code:
      (vl-load-com)
      (defun *error* (x)
    (command "layer" "m" "Survey Limit" "lt" "dashed" "" "c" "5" "" "")
    (command "layer" "m" "Survey Lines" "lt" "continuous" "" "c" "6" "" "")
                 (setq k
                        (cond ((getkword
                              ("Winglines")
        (while
               (vla-offset
                 x
               (vla-put-layer
                   "SURVEY LIMIT"
                   "SURVEY LINES"
    but still same error is coming
  7. #7
    Mechanical
    Mechanical
    AutoCAD 2014
    Oct 2009
    Lives in Abu Dhabi
    2,616
    Check the Color Control of the current layer , it might be changed to others than ByLayer .
  8. #8
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,089
    Code:
      (vl-load-com)
      (defun *error* (x)
    (setvar 'cmdecho 0)
    (defun Lyr (/ x)
         (setq x
                (cond ((getkword
                      ("Winglines")
         ) x
    (foreach lyr '(("SURVEY LIMIT" "5" "DASHED")
    	       ("SURVEY LINES" "6" "CONTINUOUS"))
      	(if (not (tblsearch "LAYER" (car lyr)))
    	 	(command "_Layer" "_N"
    			 (car lyr)  "_Color"
    			 (cadr lyr) (car lyr)
    			 "_Ltype"
    			 (last lyr) (car lyr)
               (setq k (lyr))
        (while
          (progn (initget "L")
          (setq d (getdist "\n Specify offset distance/L To change layer :")))
    		(cond
    		  ((eq d "L")(setq k (lyr)))
          		  ((eq (Type d) 'Real)
    		           (vla-offset
    		             x
    		           (vla-put-layer
    		               "SURVEY LIMIT"
    		               "SURVEY LINES"
    Surveying
    AutoCAD 2007
    Apr 2012
    85
    it working perfectly now for me without any error
    @pBe and Tharwat.....you guys are real genius.... thankx a lot for your interest and help..... your work is really appreciated.
    I want one more help from u (Sorry for making u to work again)
    In winglines segment, i want the prompt of Specify Distance [Same/Different]
    1. at same distance i want to specify distance once and then it should draw line at proper interval of that distance.
    (e.g. If i specified distance 2 then
    1st offset will be @- 2,
    2nd offset will be @- 4,
    3rd offset will be @- 6.
    Just like Offset command (after selecting object it ask Specify through point or [Exit/Multiple/Undo] <Exit>:
    When we give Multiple command it draws line at proper interval of that specified distance)
    2.For different distance it should work how it is working now.
    i.Select object
    ii. specify distance
    iii. offsetting the line
  10. #10
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,089
    That sounds like fun. But its tharwats' code really
    Cheers
  1. Offsets
    By igones in forum AutoCAD Beginners' Area
    Last Post: 15th May 2012, 04:54 am
  2. Annotation Offsets
    By magic_man1 in forum Revit General
    Last Post: 24th May 2011, 12:25 am
  3. Roofplan offsets...Need help!!!
    By truedud in forum AutoCAD Beginners' Area
    Last Post: 17th Oct 2010, 08:27 pm
  4. dim line offsets??
    By comcu in forum AutoCAD Drawing Management & Output
    Last Post: 4th May 2007, 05:48 pm
  5. Bays, offsets?
    By James in forum SketchUp
    Last Post: 16th Jan 2007, 11:54 pm
