Results 1 to 10 of 10
    Junior Member Beng's Avatar
    AutoCAD 2011
    Sep 2011
    11
    Default Converting lines to polylines
    hi all!
    i was wondering if there is a way to convert multiple lines (non collinear) into polylines?
    this to be able to add the "global width" property to the objects.
    thanks in advance
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    I will admit that I am not sure what 'collinear' means? Lines on the same plane? Or through the same point?
    As long as they are not on different Z's, PEDIT should do the trick, just choose Multiple when you are prompted to select.
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
    Senior Member Bogbadbob658's Avatar
    Bogbadbob658's Computer Details
    Windows 7
    Asus P8P67 LE
    Intel 2nd Generation Core™ i5-2500
    8GB 1333MHz Dual Channel DDR3 SDRAM
    512MB Nvidia GeForce Quadro FX 580
    1TB Samsung F3 SATA 7200rpm 32MB Cache
    24" Iiyama LCD Monitor - Full HD 1920x1080
    Architecture 2012
    Aug 2007
    Gloucester UK
    252
    Pedit then 'm' for multiple, select the lines and follow the command line prompts. Note if they are non planer you won't be able to join them to gether.
    AutoCAD 2011
    Sep 2011
    11
    Thanks for the quick reply!
    http://mathworld.wolfram.com/Collinear.html (collinear)
    but for your answer: this works, yes, but i have A LOT of lines to select. it would be much more effective to first select the lines through quick select then use the "magic tool"
  5. #5
    8GB
    280 GB
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    (And yeah, I found that about collinear too - but being slightly slow right now, English feels like my fourth language today)
    select via qselect > do something small (like move a bit and then undo to move back) > start PEDIT > M for multiple > P for previous selection.
    And I am sure some Lisp-geek will say "doh! just go use ssget"
  6. #6
    AutoCAD 2011
    Sep 2011
    11
    Awesome, thanks! you just saved my day
  7. #7
    Windows 7
    Asus P8P67 LE
    Architecture 2012
    Aug 2007
    Gloucester UK
    252
    As Tiger said but if when you use move just return through the options and nothing will move.
  8. #8
    8GB
    280 GB
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    Ahhh smrt Bog! What you are actually doing is using any old point as a basepoint and the same point as the move-to-point - didn't think of that!
  9. #9
    SLW210's Computer Details
    Windows 7 PRO
    IBM Lenovo
    ACPI x86
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    4 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    ThinkVision 22"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2011
    May 2007
    South Florida, USA
    9,116
    Use Qselect then the Express tool MPEDIT.
  10. #10
    AutoCAD 2011
    Sep 2011
    11
    n1, SLW210, thanks
  1. Converting 3D Faces into 3D Polylines
    By thissell in forum Civil 3D & LDD
    Last Post: 16th Oct 2009, 07:45 pm
  2. Converting Lines To Polylines
    By MR MAN in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Jan 2009, 02:51 pm
  3. converting LWpolylines to polylines
    By cyclingg in forum AutoCAD General
    Last Post: 17th Dec 2007, 03:16 pm
  4. converting lines to polylines
    By fastrhino in forum AutoCAD Beginners' Area
    Last Post: 24th Aug 2006, 05:56 pm
  5. trouble converting to polylines
    By jcad in forum AutoCAD Drawing Management & Output
    Last Post: 16th Nov 2005, 04:59 pm
