Results 1 to 9 of 9
    Full Member waders's Avatar
    waders's Computer Details
    Windows 7 Pro
    Snail
    8g
    ATI FirePro V5800 DVI
    (2) 20" Dell 2001FP
    Architectural
    waders's Discipline Details
    Design Tech III
    Architectural
    AutoCAD 2011
    Mar 2010
    Rochester, MN
    37
    Default Joining 2 commands
    Okay this seems like a simple one. How would I join these 2 commands so it doesn't matter if the line is a line or pline. Thanks
    Code:
    (defun c:heal2  (/ block ll ur p1 p2)
         (vl-load-com)
         (setq block (car (entsel "\nSelect Block:")))
         (vla-getboundingbox (vlax-ename->vla-object block) 'll 'ur)
         (command "_.erase" block "")
         (command
               "_.pedit"
               "_m"
               (ssget "C"
                      (setq p1 (vlax-safearray->list ll))
                      (setq p2 (vlax-safearray->list ur)))
               "_join" "_Joint" "_Both"
               (distance p1 p2)
    Code:
    (defun c:HEAL (/ block ll ur objecttojoin)
         (vl-load-com)
         (setq objecttojoin
                    (ssget "C"
         (command
               "_.join"
               (ssname objecttojoin 0)
               (ssname objecttojoin 1)
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,106
    If you don't mind converting the lines to plines , you can use heal2 for both if you set peditaccept to 1
    Code:
    (defun c:heal2  (/ block pea ll ur p1 p2)
         (vl-load-com)
         (setq pea (getvar 'Peditaccept))
         (setvar 'PeditAccept 1)
         (command
               "_.pedit"
               "_m"
               (ssget "C"
               (distance p1 p2)
         (setvar 'PeditAccept pea)
    Windows 7 Pro
    Snail
    8g
    (2) 20" Dell 2001FP
    Architectural
    Design Tech III
    Architectural
    AutoCAD 2011
    Mar 2010
    Rochester, MN
    37
    First of all thanks pBe for looking at this.
    If I had my choice I would like to convert plines into lines the join. But shouldn't I be able to add a:
    Code:
    (cond
      ((= $ent2 line)(c:heal))
      ((= $ent2 lwpolyline)(c:heal2))
    $ent2 would be either line or lwpolyline pending which on is picked.
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,106
    Quote Originally Posted by waders View Post
    Its either you explode the selection to turn it to lines then join or use heal2 then explode.
    Code:
    (cond
    Code:
    (defun c:heald  (/ pea block ll ur objs p1 p2)
         (vl-load-com)
         (setq objs (ssget "C"
                      (setq p2 (vlax-safearray->list ur))))
    (if (eq (cdr (assoc 0 (entget (ssname objs 0)))) "LWPOLYLINE")
         (command "_.pedit" "_m" objs "" "_join" "_Joint" "_Both"
               (distance p1 p2) "")
         (command "_.join" (ssname objs 0) (ssname objs 1) "")
    Windows 7 Pro
    Snail
    8g
    (2) 20" Dell 2001FP
    Architectural
    Design Tech III
    Architectural
    AutoCAD 2011
    Mar 2010
    Rochester, MN
    37
    Thank you pBe. That works great. I see how you did it, but know I just need to figure out how you came up with it. I'm going to see if I can figure out how to filter out to only select blocks. If I do I'll repost. Thanks again for your help.
  6. #6
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,106
    Good for you, hope you'll learn from it. It is your code after all.
    If you mean multiple selection in one-go. Yes, it can be done. Pretty sure you'll figure it out on your own. keep us posted
    Cheers
  7. #7
    Windows 7 Pro
    Snail
    8g
    (2) 20" Dell 2001FP
    Architectural
    Design Tech III
    Architectural
    AutoCAD 2011
    Mar 2010
    Rochester, MN
    37
    Default Selecting more then one block
    Okay I got so I can select only a block. But if I select more then one block it only works on one an ignore's the others. How would I make it run for each item in the selection set? Thanks
    Code:
    (defun c:ee (/ pea $blk block ll ur objs p1 p2)
      (vl-load-com)
      (setq $blk (ssget '((0 . "insert"))))
      (setq block (ssname $blk 0))
        (command "_.pedit"
          "_m"
          objs
          "_join"
          "_Joint"
          "_Both"
          (distance p1 p2)
    Windows XP
    Construction
    Construction
    AutoCAD 2009
    Apr 2010
    2,106
    lets try something
    Code:
    (defun c:hint ()
       (if	(setq ss (ssget '((0 . "INSERT"))))
    		  	(setq pt  (cdr
    				 (assoc  10
    				   (entget
    				     (setq e (ssname ss (setq i (1- i))))
    		  	(command "_rotate" e "" "_non" pt "180")
         )(princ)
    Scroll down when you're ready
    (defun c:ee (/ pea $blk block i ll ur objs p1 p2)
      (vl-load-com)
      (if (setq $blk (ssget '((0 . "insert"))))
    	  (repeat (setq i (sslength $blk))
    	    	(setq e (ssname  $blk (setq i (1- i))))
    	  	(vla-getboundingbox (vlax-ename->vla-object e) 'll 'ur)
    	    	(entdel e)
    			   ""  "_join" "_Joint"
    			   "_Both" (distance p1 p2)
        (princ "\nNo Blocks Selected")
    See if you can use that as reference.
    This is CAD Tutor after all
  9. #9
    Windows 7 Pro
    Snail
    8g
    (2) 20" Dell 2001FP
    Architectural
    Design Tech III
    Architectural
    AutoCAD 2011
    Mar 2010
    Rochester, MN
    37
    Hey pbe, I think I got it not quite sure I understand why we need to us sslength and get the block's insertion point. But it does work. Thank you very much for you time.
    Code:
      (vl-load-com)
        (setq pt (cdr
          (assoc 10
           (entget
            (setq block (ssname $blk (setq i (1- i))))
     (command "_.pedit"
       "_m"
       objs
       "_join"
       "_Joint"
       "_Both"
       (distance p1 p2)
        );repeat
       );if
  1. joining tables
    By gpd in forum AutoCAD General
    Last Post: 1st Sep 2011, 07:59 am
  2. Joining linetypes
    By johnengineer in forum AutoCAD Drawing Management & Output
    Last Post: 16th May 2007, 06:19 pm
  3. Joining Polylines
    By Rooster in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2005, 07:36 pm
  4. joining 3d faces
    By spyace in forum AutoCAD Beginners' Area
    Last Post: 28th Aug 2003, 09:10 pm
Tags for this Thread
