Page 1 of 2 1 2 LastLast
Results 1 to 10 of 20
Thread: Helical Truss
    Full Member
    BMWiley's Computer Details
    Windows 7
    Dell T7500
    Intel Xeon E5620 @2.40GHz
    12.0 GB
    Nvidia Quadro 4000
    500G
    Server
    Dual 24" LCD Monitors
    Multi-disciplinary
    BMWiley's Discipline Details
    Draftsman - Custom Fabrication
    Multi-disciplinary
    Theatrical , Scenic Drafting, Design. CNC Programming
    AutoCAD 2011
    Oct 2008
    Blackwood, NJ
    25
    Unhappy Helical Truss
    How is everyone this glorious morning!!!
    Ok so im in a pickle. Having problems creating a helical truss/ shape. Ive managed to get a simple spline spiral. Which im still not 100 percent happy with. But it will suffice for right now.
    Now one of my problems is extruding, and offsetting.
    Im pretty ok at 3d modelling, but when it comes to complex shapes i fall flat on my face. Ive including a dwg that shows a plan view of the structure, as well as my 3d spine. the small circles are the truss cords. Its a 16" flat truss, ran parallel with another to create a spiral ribbon.
    The plan view is from the designer, ive noticed but maybe its not true... their helix doesnt seem consistent.
    I know im leaving a lot of info out, please ask all thw questions youd like. Ill be here all day.
    Using, 64bit ACAD 2011 Nilla
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,020
    What will your truss be supporting?
    Full Member
    Windows 7
    Dell T7500
    12.0 GB
    Nvidia Quadro 4000
    500G
    Server
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2011
    Oct 2008
    Blackwood, NJ
    25
    Itself... Its an architainment piece. Imagine a walk way through the center, and scrim stretched between the paralleled truss. The red in the plan view is the open area.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,020
    Were you thinking of using a tube shape (square/rectangular) or a cylindrical shape to construct the truss?
    Could the multiple 3" diameter circles suggest you are going cylindrical?
    Is there a kink of sorts in your spline or is it an optical illusion?
  5. #5
    Full Member
    Windows 7
    Dell T7500
    12.0 GB
    Nvidia Quadro 4000
    500G
    Server
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2011
    Oct 2008
    Blackwood, NJ
    25
    the cords are 3 inch aluminum and the diagonal pipe will be 1 1/2". Here is a image of one of their references. In the process of inquiring if a model exsists, and is available.
  6. #6
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Helix
    Sweep
    then a whole bunch of work for the connecting pieces
    or
    Helix
    Curve driven pattern in a modern program like Autodesk Inventor.
    Hmm, haven't they added a curve driven Array in AutoCAD? Might not be so bad afterall.
    Measure or Divide if the curve driven Array isn't in there (but I think maybe it is).
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  7. #7
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Quote Originally Posted by BMWiley View Post
    Ive managed to get a simple spline spiral. Which im still not 100 percent ....
    How did you get that - it doesn't look right to me. Look at end view - it should be circular.
    Did you use the Helix command?
  8. #8
    Full Member
    Windows 7
    Dell T7500
    12.0 GB
    Nvidia Quadro 4000
    500G
    Server
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2011
    Oct 2008
    Blackwood, NJ
    25
    Yes there is a kink, i copied one section multiple times. and havent smoothed it out yet.
  9. #9
    Full Member
    Windows 7
    Dell T7500
    12.0 GB
    Nvidia Quadro 4000
    500G
    Server
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2011
    Oct 2008
    Blackwood, NJ
    25
    When i tried the helix command the results werent what i was looking for. When laid on top of the designers plan, it didnt match, what makes me think either theirs may not be possible, or its not consistent. Or maybe im just wrong... which isnt a far stretch. What i did to get the kink was i mapped out one revolution with a spline, then copied, and tried doing little modifications to get smooth. But yes, its not exactly perfect, im not 100% percent happy, but i wanted to figure out the process.
  10. #10
    Full Member
    Windows 7
    Dell T7500
    12.0 GB
    Nvidia Quadro 4000
    500G
    Server
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2011
    Oct 2008
    Blackwood, NJ
    25
    Quote Originally Posted by JD Mather View Post
    Helix
    Sweep
    or
    Ive managaed to create something a little better with helix... not sure what i did wrong first time around, but on a better track. Thanks. Still stumped but in a better place now.
  1. Helical Shape
    By virusxp in forum SolidWorks
    Last Post: 9th Aug 2011, 12:47 pm
  2. Drawing a truss with inventor (structural members??)
    By Hendrik in forum Autodesk Inventor
    Last Post: 17th May 2011, 06:56 pm
  3. timber roof truss
    By learnfast in forum AutoCAD Beginners' Area
    Last Post: 20th Mar 2011, 03:15 pm
  4. Roof Truss Design
    By bertsquall in forum Architecture & ADT
    Last Post: 26th Nov 2009, 01:04 am
  5. How Do i work out Roof truss calculations
    By Daffy in forum AutoCAD General
    Last Post: 18th Mar 2007, 12:04 pm
