Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 38
    Senior Member stenews's Avatar
    stenews's Computer Details
    WindowsXp Pro (SP3)
    Hp workstation xw6200
    AutoCAD 2013
    Dec 2008
    somewhere in Italy
    155
    Default viewbase command help!
    Hi guys,
    does anyone of you to know why I can't set the hidden lines viewbase option to shaded with visible lines mode?
    Thanks,
    Stefano
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,457
    Is this the effect you were looking for?
    Is the option available in 2012? I used 2013. I don't have 2012 loaded on my home computer.
    WindowsXp Pro (SP3)
    AutoCAD 2013
    Dec 2008
    somewhere in Italy
    155
    Hi ReMark,
    yes it is...do it using the attached file and see if you can to the same thing.
    I use 2013 too
    let me know what's the problem...
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,176
    Quote Originally Posted by stenews View Post
    Hi ReMark,
    I use 2013 too
    No problems that I can see.
    Unless you are unaware that each of these views can have different visual style settings.
    Left click on one you wish to change, then in the right click shortcut menu select EDIT VIEW.
    Then take a look at the image...
  5. #5
    WindowsXp Pro (SP3)
    AutoCAD 2013
    Dec 2008
    somewhere in Italy
    155
    right...but the style does not change...it has no shade colour...it still remain in black and white
    Where I'm wrong may be I changed same setting...
    try to hit shaded with visible lines
  6. #6
    WindowsXp Pro (SP3)
    AutoCAD 2013
    Dec 2008
    somewhere in Italy
    155
    Hi Dadgad...
    see what I mean...if I try to apply any colours I always see the view like black and white but If you try to copy and past the draw in a new template it works again...why
  7. #7
    AutoCAD 2012
    Nov 2011
    3,176
    I see what you mean, I also did this using 2013, like ReMark,
    but I can't get it to display any shaded coloration either.
  8. #8
    WindowsXp Pro (SP3)
    AutoCAD 2013
    Dec 2008
    somewhere in Italy
    155
    and If you try to copy and past the all draw in a new fresh template it works again...why?
    may be I changed same internal settings...accidentally but what?
  9. #9
    AutoCAD 2012
    Nov 2011
    3,176
    Hi Dadgad...
    Have you experimented with the right click (on the Layout tab) option,
    EXPORT LAYOUT TO MODEL.
    If you use that it is sort of like a quicker version of SOLPROF.
    That won't fix the issue you are having here, but it is interesting.
  10. #10
    WindowsXp Pro (SP3)
    AutoCAD 2013
    Dec 2008
    somewhere in Italy
    155
    right I'll give it a try...thanks to all of you for the time wasted helping me I appreciate
    but to me it's a bug...or something like that
  1. AutoCAD 2012 ViewBase command
    By ReMark in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th Sep 2012, 12:09 am
  2. viewbase printout resolution
    By stenews in forum AutoCAD General
    Last Post: 25th Apr 2012, 03:13 pm
  3. Where is VIEWBASE?
    By kduck63 in forum Map 3D
    Last Post: 6th Apr 2012, 02:58 pm
  4. Use AutoCAD’s VIEWBASE command to create 2D views of your 3D model
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 21st Mar 2012, 07:10 pm
  5. Acad 2012: Viewbase command?
    By 43st in forum AutoCAD 3D Modelling & Rendering
    Last Post: 29th Nov 2011, 12:29 pm
