Results 1 to 7 of 7
    Junior Member
    not specified
    Jun 2006
    Slovenia
    15
    Default HELP:extruding with path
    I drew spiral out of several curved lines and now I want to extrude it. I am using spiral for extrusion path and a circle for extrusion's basis. But there comes the problem-I cannot extrude it. I guess it's because spiral consists of many curved lines and not just one. Therefore I would like to know, how do I join all those curved lines to be recognized as only one???
    Senior Member
    AutoCAD 2008
    Oct 2003
    Germany
    228
    Try out PEDIT3D from www.black-cad.de
    Good luck
    Jochen
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    Hello Knez
    Start the 3DPOLY command and with the runing osnap set to END click the endpoints of the lines. This way you will draw a 3D polyline over the existing lines and you will be able to extrude a circle along it.
    And just if no one told you before: welcome!
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Junior Member
    not specified
    Jun 2006
    Slovenia
    15
    I've tried with 3dpoly command but I get a spiral that has no simmetry. Can I send it to you??I really don't know what I do wrong there..
  5. #5
    AutoCAD 2006
    Nov 2002
    3,540
    Use the file manager to upload a drawing. Preferable save it back in AutoCAD 2000 or even 14 format -it will be accessible for more people. Post here the hyperlink.
  6. #6
    Junior Member
    not specified
    Jun 2006
    Slovenia
    15
    hmmm, I cannot log in there...
  7. #7
    AutoCAD 2006
    Nov 2002
    3,540
    Read the text on that page:
    To use the guest account, login with the username guest and leave the password box blank.
