Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
    Junior Member
    AutoCAD 2012
    Oct 2012
    20
    Default Volume of 3d mesh?
    Hello,
    I'm using AutoCAD 2012 to project a hull of a ship I'm about to build. I'm designing it in 3d. I have red many tutorials, but I'm still not very good at 3d modeling, so I'm learning as I go.
    I decided that for complex 3d shapes, working with meshes is best option. However, as I'm designing the before mentioned hull, I need to frequently check the volume of that hull to see if it passes under design limits.
    However, I can't figure a way to do that. MEASUREGEOM command doesn't work with so complex shape, MASSPROP works only with 3d Solids, and I don't know any other commands.
    I tried converting my mesh to 3d Solid, but got following error: "Mesh not converted because it is not closed or it self-intersects.
    Object cannot be converted.".
    After step-by-step redrawing I figured out that if two vertexes are on each other, AutoCAD cannot convert mesh to solid. However, I can't even merge two vertexes into one. Tools to work with mesh are very very poor here (comparing to 3ds MAX).
    However, these are details, main question is: how to figure out exact volume of specific mesh?
    I'm attaching a .dwg file of my project (this is very early stage).
    Please help, I'm stuck with this for more than 2 days of intense manual-reading and googling.
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,007
    Quote Originally Posted by laukejas View Post
    ... but I'm still not very good at 3d modeling, so I'm learning as I go.
    ....Tools to work with mesh are very very poor here (comparing to 3ds MAX).
    How much training/experience with 3DS Max?
    How much training/experience with AutoCAD?
    Search here http://au.autodesk.com for past class Making a Mesh of Things.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,007
    I would recommend at least 6 months to learn the ins and outs of tackling something this complex.
    Junior Member
    AutoCAD 2012
    Oct 2012
    20
    Well, I attended 3ds MAX classes 8 years ago, I still remember some things, did some work on my own, but nothing professional.
    I have worked with AutoCAD for about a year, few tutorials, and then self-learning as I did my previous ship project (which eventually I built in reality). But it was only in 2d, and not very complex.
    Now that I started this new project, I decided to take a step further. I completed all the tutorials in http://www.we-r-here.com/cad/tutorials/index.htm in about a week, but it practically never gets to complex 3d modeling and calculations.
    So if you know any good tutorials on 3d modeling, please tell.
    But for now, can you help me with that volume calculation? How should I do it?
  5. #5
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,585
    Bingo. AutoCAD is (in my opinion) one of the worse programs to use for modeling and editing meshes, and my opinion includes the latest releases of AutoCAD that has shown a great increase in mesh support. Mesh modeling should be tackled using a NURBS based program, such as Rhino or 3DS Max. Meshes do not contain volumetric information that I have ever known. I'm sure there's ways to calculate mass, but not out of the box.
    I'd hate to be the bearer of bad news but continuing to use AutoCAD for meshes will push you further down the rabbit hole. Have you tried using solids at all? I've managed to do some pretty advanced 3D modeling with solids. Not trying to toot my own horn here, but in a recent post in the Showcase forum I was showing off me modeling a guitar I own here: http://www.cadtutor.net/forum/showth...project-for-me
    Everything you see there is by means of solids, not meshes. If you think that what I have done using solids can be utilized in designing your hull, then I'd be glad to help (among plenty others) guiding you along. All you would need to do is give a good example of where you want to end up, and we'll help you on the approach and continual procedures using a slew of solid modeling techniques.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  6. #6
    Super Member SEANT's Avatar
    AutoCAD 2012
    Aug 2005
    Rhode Island
    1,971
    This looks like an interesting project.
    I’ve included a file that demos a couple of options.
    The original geometry did require correction. The geometry also suggests that symmetry is desired.
    If that is correct then the green model (actually block inserts) offers some interesting possibilities. Via the BEDIT command, one quadrant of the model can be isolated in AutoCAD’s Block Edit Mode. This will allow modification to the base geometry - so, for instance, the solid’s vertices can be stretched (similar to mesh editing) by setting the correct selection filter (SUBOBJSELECTIONMODE).
    Any change to this Block geometry will, when saved, propagate through all four sections.
    The MASSPROP command, used in Block Editing mode, will give a volume that can be multiplied by 4 to account for the entire model.
    Once the target shape and volume are achieved, the 4 blocks can be EXPLODEd back to Solids, then UNIONed together.
    The red Solid was created by lofting the ribs (5 sections), using the “Ruled” option in the Loft Settings dialog. Use the MASSPROP command to get the solid’s volume.
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,585
    Seant, you mean "MASSPROP". I know you know the command, but was mistyped. Just simply clarifying is all. And good use of the LOFT command in your modification. Exactly my point that solids can still be plenty powerful.
  8. #8
    AutoCAD 2012
    Aug 2005
    Rhode Island
    1,971
    Good catch Tannar. And, I also agree, 3DSolids are the best.
  9. #9
    Inventor 2013
    Sep 2007
    Williamsport, PA
    7,007
    There are a bunch of 3D modeling tutorials in my signature (a little old - written for 2007). Whether they are any good or not.....
  10. #10
    Junior Member
    AutoCAD 2012
    Oct 2012
    20
    SEANT, thanks, that looks promising. I think I would stay with red one - seems easier to work with. But with it, being 3d Solid, how do add, delete, merge vertexes?
    JD Mather, I will look into these tutorials, thanks.
    StykFacE, your guitar looks very good. Really nice work. You asked what I want to end up, I can't show yet, but idea here is to design a hull shape that has needed hydrodynamics. Long time to explain, but basically I'll need to work with this basic shape, adding, deleting and merging vertexes, edges, faces, making it more and more complex, and keeping a look out for the volume. Then I'll export it to another hydrodynamics calculation program for fine tuning.
    The shape will have symmetrical sides, but bow and stern will be different.
  1. FEA meshing - why not 2d mesh -> 3d mesh ???
    By Ziggi in forum AutoCAD General
    Last Post: 29th Sep 2011, 08:43 pm
  2. Volume
    By titanium221 in forum AutoCAD Beginners' Area
    Last Post: 6th Mar 2011, 04:05 am
  3. Volume
    By StevenMc in forum AutoCAD 3D Modelling & Rendering
    Last Post: 19th Feb 2010, 01:21 pm
  4. volume
    By dyollnave in forum AutoCAD Beginners' Area
    Last Post: 9th Aug 2007, 10:29 pm
  5. volume
    By daviddodda in forum AutoCAD General
    Last Post: 1st Dec 2004, 08:53 am
