Results 1 to 9 of 9
    Senior Member
    AutoCAD 2010
    Aug 2010
    211
    Default Need help with some codes please
    Hello guys .
    Can someone help me with this code ? it doesn't rename the block "FT"
    Code:
    (while
      (setq Myblk (tblnext "BLOCK" (null Myblk)))
       (if (eq (cdr (assoc 2 Myblk)) "FT")
           (setq entlst (entget (tblobjname "BLOCK" (cdr (assoc 2 Myblk)))))
           (entmod (subst (cons 2 "CO") (assoc 2 entlst)
               entlst
    Lee Mac's Computer Details
    Windows 7 Ultimate (32-bit)
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    Code:
    (if (setq ent (tblobjname "BLOCK" "FT"))
        (entmod (subst '(2 . "CO") '(2 . "FT") (entget (cdr (assoc 330 (entget ent))))))
    Lee Mac Programming
    Just another Swamper
    Senior Member
    AutoCAD 2010
    Aug 2010
    211
    Thank you LEE .
    Why you used code 330 ? I see it is 330 Soft-pointer ID/handle to owner object and I can't understand what does it mean .
    Thankxxxxx
    Senior Member marko_ribar's Avatar
    marko_ribar's Computer Details
    Windows 7 Ultimate X64
    Intel quad core CPU 4x2.66GHz, 8GB RAM
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    NVIDIA GeForce 6600 GT
    250 GB
    500 GB
    Samsung 17''
    Architectural
    marko_ribar's Discipline Details
    Architecture, project designer, project visualisation
    Architectural
    space design - modeling and animations
    AutoCAD 2012
    Feb 2010
    Belgrade, Serbia, Europe
    327
    Quote Originally Posted by Sweety View Post
    You can't rename just single block reference without redefining block definition (owner of all blocks with the same name).
    Marko Ribar, d.i.a. (graduated engineer of architecture)
    M.R. on YouTube
  5. #5
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows XP
    Construction
    pBe's Discipline Details
    Construction
    Camp Construction planning and details
    AutoCAD 2009
    Apr 2010
    2,089
    Quote Originally Posted by Lee Mac View Post
    Code:
    Wow, I didn't know that
    That is so cool
  6. #6
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    Thank you LEE .
    You're welcome!
    The 330 DXF Group code is always a pointer to the parent / owner entity, in this case the BLOCK_RECORD entity (AcDbBlockTableRecord object), which is the parent of the BLOCK entity (AcDbBlockBegin object). The AcDbBlockTableRecord object is the object found in the Visual LISP Block Collection and it is this entity / object that should be renamed to rename all references of the block in the drawing.
    Every AutoCAD Block Definition uses the following entity hierarchy:
    Code:
    +-- TABLE (AcDbBlockTable)
    +--+-- BLOCK_RECORD (AcDbBlockTableRecord)
       +--+-- BLOCK (AcDbBlockBegin)
          +--+-- < Block Geometry Entity >
             +-- ENDBLK
    Lee Mac Programming
  7. #7
    Multi-disciplinary
    Multi-disciplinary
    AutoCAD 2013
    Aug 2008
    London, England
    15,708
    Quote Originally Posted by pBe View Post
    That is so cool
    Cheers dude
    Lee Mac Programming
  8. #8
    INTEL compatibile
    quad core 4x2.66GHz
    8GB
    250 GB
    500 GB
    Samsung 17''
    Architectural
    Architectural
    AutoCAD 2012
    Feb 2010
    327
    I did some research :
    blocks
    Code:
    also
    Code:
      (if (setq ent (cdr (assoc -2 (tblsearch "BLOCK" "FT"))))
    layers
    "0" layer can't be renamed, but color can be set to it (changed to "red" - color 1)
    Code:
      (if (setq ent (tblobjname "LAYER" "0"))
          (entmod (subst '(62 . 1) '(62 . 7) (entget ent)))
    views
    Empty table view (tblnext "VIEW" T) => nil
    Firstly create view "MR"
    Code:
      (if (setq ent (tblobjname "VIEW" "MR"))
          (entmod (subst '(2 . "VR") '(2 . "MR") (entget ent)))
    ltypes
    "Continuous" ltype can't be modified so you have to load new ltype
    Firstly load ltype "Dashed"
    Code:
      (if (setq ent (tblobjname "LTYPE" "Dashed"))
          (entmod (subst '(2 . "MR") '(2 . "Dashed") (entget ent)))
    styles
    "Standard" style can't be renamed, but font can be set to it (changed to "simplex.shx")
    Code:
      (if (setq ent (tblobjname "STYLE" "Standard"))
          (entmod (subst '(3 . "simplex.shx") '(3 . "arial.ttf") (entget ent)))
    ucss
    Empty table ucs (tblnext "UCS" T) => nil
    Firstly save ucs "MR"
    Code:
      (if (setq ent (tblobjname "UCS" "MR"))
    dimstyles
    "Standard" dimstyle can't be renamed and modified
    Firstly save dimstyle "MR"
    Code:
      (if (setq ent (tblobjname "DIMSTYLE" "MR"))
    vports
    Empty table vport (tblnext "VPORT" T) => nil
    Firstly create vport "MR"
    Code:
      (if (setq ent (tblobjname "VPORT" "MR"))
    appid
    "ACAD" appid can't be modified, so this won't work
    Code:
      (if (setq ent (tblobjname "APPID" "ACAD"))
          (entmod (subst '(2 . "MR") '(2 . "ACAD") (entget ent)))
    M.R.
    M.R. on YouTube
  9. #9
    Senior Member
    AutoCAD 2010
    Aug 2010
    211
    Thank you LEE for the nice explanations
    Also thank you Marko for that nice examples .
  1. 4 dxf codes for 10
    By Michaels in forum AutoLISP, Visual LISP & DCL
    Last Post: 14th Aug 2010, 05:31 pm
  2. New codes of ssget to me
    Last Post: 14th Aug 2010, 02:38 pm
  3. Help with Autocad codes like %%d
    By Lithium in forum AutoCAD Beginners' Area
    Last Post: 11th Feb 2009, 08:51 am
  4. codes
    By chloe18 in forum AutoCAD Beginners' Area
    Last Post: 27th Sep 2007, 01:05 pm
  5. DXF Codes
    By Spageddie in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Sep 2005, 11:36 pm
