Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 29
    Full Member
    turboCAD's Computer Details
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    88
    Default how do I join the lines that form a cube, not solid. I need single cubic line-object
    hello!
    I drew a cube using polylines by changing ucs.
    I want to join the polylines so that the cube contour becomes one single object.
    Since the lines are in different planes I can not join them.
    How could I unite those 12 lines so they become a cube non solid(I plan on placing a sphere inside some of the cubes and then use "shade" for visualization so if the cube is solid I won't see the spheres).
    Thank you!
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,140
    You could have just as easily created surfaces using lines.
    If you can't see inside the cubes what is the point of putting a sphere inside?
    Senior Member Bogbadbob658's Avatar
    Bogbadbob658's Computer Details
    Windows 7
    Asus P8P67 LE
    Intel 2nd Generation Core™ i5-2500
    8GB 1333MHz Dual Channel DDR3 SDRAM
    512MB Nvidia GeForce Quadro FX 580
    1TB Samsung F3 SATA 7200rpm 32MB Cache
    24" Iiyama LCD Monitor - Full HD 1920x1080
    Architecture 2012
    Aug 2007
    Gloucester UK
    252
    Try drawing a square in plan using a polyline. Copy it form 0,0,0 to 0,0,x where x is the length of the side. Change the ucs to an isometric view (doesn't matter which one). Make sure you have snap end on and then draw ploylines from corner to corner to complete the cube.
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,140
    If it has to be a solid then draw a box then extrude it. Now shell the resultant solid. You can put your sphere inside the box before or after you have executed the SHELL command (Solid Editing panel).
  5. #5
    Full Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    88
    the sphere is circumscribed by the cube made from lines NOT solid cube(the cube is just a frame I use for aligning the spheres).
    sphere+cubical frame around it form an atom that I will use repeatedly
    That is why I need the cube to be made only out of lines that do not mask any spheres.
  6. #6
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,140
    Cube with sphere. Cube is a solid. The one on the right has been sliced open. 2Dwireframe is the visual style.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,140
    Cube with sphere in Realistic visual style.
  8. #8
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Group the lines
    or
    make the cube solid and apply transparent texture.
    reading the clarification of your problem description you then might block the sphere and group.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  9. #9
    Full Member
    Windows7
    AutoCAD 2011
    Aug 2012
    București, România
    88
    I need the cube to be one continuous polyline block made of its 12 individual lines so that it is easy to copy/paste and I do not have to select each of the 12 lines separately
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,140
    See post #6 and 7. The cube is a single entity.
  1. Break the line with single pick object
    By nalsur8 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Nov 2011, 12:29 pm
  2. Replies: 4
    Last Post: 27th Sep 2010, 09:50 pm
  3. Join points by a line to form circle
    By symoin in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th May 2010, 12:24 pm
  4. LISP to join many lines to a single 3D Pline
    By Phiphi in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Feb 2009, 04:07 am
  5. join 2 lines/plines into a single pline with just a click!
    By gvlisnas in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th Jan 2009, 07:12 pm
