Results 1 to 4 of 4
Thread: About units
    Junior Member
    AutoCAD 2012
    Feb 2012
    17
    Unhappy About units
    Hi everyone i still cant understand about the units
    i open acad iso template to work in mm and the insertion scale is also showing in mm.what if i want to draw in meters or cm. iam so confused
    Super Moderator Tiger's Avatar
    Tiger's Computer Details
    Windows 7 Enterprise 64 bit
    Dell Precision M4500
    Intel Core i5 2.40GHz
    8GB
    NVIDIA Quadro FX 880M
    280 GB
    2 x Samsung SyncMaster 2443 24''
    AutoCAD 2012
    Nov 2006
    Sthlm, Sweden
    4,595
    If you want to draw in meters, you change the Units to Meters (type UNITS to open the Units dialogue box) and then you draw in meters. Or change it to centimeters. Or whatever you like.
    One thing to keep in mind though, is that if you change UNITS, that doesn't affect what you have aldready drawn. You can't use Units to scale your objects from millimeters to meters. The Units-command controls how AutoCAD scales content (blocks and externals references) that you insert in your drawing.
    Life doesn't suck, although we all go through periods when it may be easier to think that, than to discern the solution to whatever problem is the most formidable
    at the moment in one's personal UCS.
    Go to PLAN view instead. - Dadgad
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,039
    Have you seen this tutorial re: Units and Scales?
    http://www.cadtutor.net/tutorials/au...and-scales.php
    The only way I know that you can specify the units (mm, cm or m) you are drawing in is via the -DWGUNITS command. There you can select from the three most common metric units (millimeters, centimeters and meters) as well as imperial units.
    Type the command at the Command Line and follow the prompts. This is what you will see:
    Drawing units:
    1. Inches
    2. Feet
    3. Millimeters
    4. Centimeters
    5. Decimeters
    6. Meters
    Unit for length <3>: 4
    Drawing unit display formats:
    1. Scientific
    2. Decimal
    Linear display format <2>: accept the default
    Linear display precision <4>: accept the default
    Scale objects from other drawings upon insert? [Yes/No] <Yes>: accept the default
    Match INSUNITS to drawing units? [Yes/No] <Yes>: accept the default
    ** WARNING: you have changed the unit for this drawing database. **
    ** All new objects will be drawn according to the new unit, but **
    ** existing objects will not change size unless you specifically **
    ** ask to have automatic scaling occur. **
    Scale objects in current drawing to reflect change in units? [Yes/No] <Yes>: in an empty drawing this is of no consequence
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    If you are in a blank drawing then simply use UNITS command, set Length to Decimal. Now when you draw you will be thinking in mm or Meters, just as the tutorial talks about, see Remark's post with the link.
    That is it, change to Decimal, draw in the unit you want. Enter 1 unit for a line length and it is a mm, or it can be 1 Meter, but not both in the same drawing. In a drawing assumed to be mm then if a meter is needed you will input 1000 in a command, if the unit is Meters then you will input 1 in a command for 1 meter.
    Plot scales will be vastly different depending on which unit you are assuming for your drawing as title blocks in a layout will be in mm regardless of your model space assumed unit of mm or M.
    Text height will be set depending on whether your drawing is mm or M, and whether or not you are using Annotative scaling. Ditto for dimstyles.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  1. Units
    By MemberX in forum AutoCAD Beginners' Area
    Last Post: 6th Feb 2012, 04:34 pm
  2. Units
    By IronHorse in forum Autodesk Inventor
    Last Post: 26th Feb 2009, 12:02 pm
  3. units
    By rollie in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Jan 2009, 09:35 pm
  4. About Units
    By Polly in forum AutoCAD General
    Last Post: 25th Sep 2008, 05:08 pm
  5. Need Help With Units
    By mobo57 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 1st Apr 2008, 01:53 pm
