Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 27
Thread: solid walls
    Full Member
    AutoCAD 2012
    Mar 2012
    30
    Default solid walls
    hi all,
    my problem is that I ve a white line cross my building outside wall, which shouldt not exist. After Union it happened... How I can remove this line. I ve already tried to the command explode. It's not such a good solution. I want to keep my walls solid.
    cheers,
    jester
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Have you zoomed in really close to where you joined them?
    You may notice that they were not perfectly aligned when you joined them.
    If that is the case you can probably fix it with your solid editing tools.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,119
    Could it be you have some 2D geometry showing up? A stray line perhaps?
    Post a copy of the DWG file and someone here will take a look at it.
    Full Member
    AutoCAD 2012
    Mar 2012
    30
    Link
    Thanks a lot guys
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,119
    Sorry...that site is blocked by our IT department.
    Can you attach a copy of the DWG file to your next post? Thanks.
  6. #6
    Full Member
    AutoCAD 2012
    Mar 2012
    30
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,119
    It looks like you a have a few stray lines left over from the design process but you would have to move objects temporarily in order to see them.
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,119
    These are just a few of the ones I found on this layer. You might have others on layers that I froze.
    Note: I made the lines white so they would show up better in this image.
    I found at least one piece of geometry that doesn't seem to fit up right as well on this layer.
  9. #9
    Full Member
    AutoCAD 2012
    Mar 2012
    30
    done.
    I can't fix that in red ellipse. could you take another look, please?
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,119
    Did you find these too?
  1. Replies: 2
    Last Post: 30th Mar 2012, 12:28 am
  2. AutoCAD 2010 - Polyline Quirk - Not showing up as solid when they are drawn solid
    By rwhitt0724 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 18th Dec 2010, 01:29 am
  3. convert 2D walls to AEC walls?
    By Cad Monkey 2 in forum Architecture & ADT
    Last Post: 7th Dec 2010, 02:56 pm
  4. Lisp to draw an outline around solid surface (hatch) then removes solid?
    By sim_rx3 in forum AutoLISP, Visual LISP & DCL
    Last Post: 21st Oct 2008, 03:50 am
  5. Plugins for drawing cavity walls, party walls etc.
    By LukeR in forum AutoCAD Drawing Management & Output
    Last Post: 3rd Jan 2007, 08:24 pm
Tags for this Thread
