Results 1 to 10 of 10
    Senior Member
    MEP 2010
    Sep 2005
    Leeds, England
    227
    Default Light pass through a solid
    Is it possible to get light to pass through a solid when glass is applied to it?
    as you can see I have modeled a kitchen wall unit with a glass front and set up a spotlight inside, when I render it the light cannot be seen through the glass, anyone got any ideas or had any other similar problems.
    Senior Member Lazarus's Avatar
    Lazarus's Computer Details
    Windows 7 x64
    ASUS P5Q-E
    Intel Core2 Quad Q9550
    8Gb DDR2 800Mhz
    ATI HD4850
    WD Caviar Black
    Dell U2311H
    AutoCAD 2010
    Apr 2006
    Skopje,Macedonia
    206
    Ok what i did was:
    crate the solid,copy the front face(it creates a region),extrude the region say 3-4mm(it represents the glass),shell the original solid/wall unit(remove the front face and shell say 1.5-2cm).....in my case i've placed a point light inside the wall unit and added a spot light outside just so i can see the whole object.
    Now i'm sure there's another way to do this but this procedure was the first thing to pop into my mind
    Hope this helps.
    Senior Member
    MEP 2010
    Sep 2005
    Leeds, England
    227
    I have this
    what I am wanting to achieve is the light to illuminate the glass, without having to manually illuminate the object, I’ll upload a img of what I am aiming for later.
    Senior Member
    MEP 2010
    Sep 2005
    Leeds, England
    227
    ok here we are. I have just illuminated the glass to give the effect of light refracting inside, I was hoping to achieve this by use of internal lights alone as with illuminate, the illumination is too uniform but I think this is the best I will get it.
    I am going to change to shelf inside the unit to glass to allow some light to pass through into the bottom part of the unit.
    I don’t think I can get it any better to be honest. thank you for your reply Lazarus
  5. #5
    Senior Member
    MEP 2010
    Sep 2005
    Leeds, England
    227
    So heres the complete picture but with light the light passing nicely through the glass.
    Thank you once again!
  6. #6
    Super Member Mr T's Avatar
    AutoCAD 2007
    Nov 2002
    Loch Oich SCOTLAND...
    1,641
    Adjusting the material to be mirror like ?
    Nice render.
    Nick
    http://www.flickr.com/photos/80049703@N00/ http://mtbnick.fotopic.net/
    http://s240.photobucket.com/albums/ff241/dyNick_Scots/
    http://designgraphicsshowcase.blogspot.com/
    High School Classroom - 21 AutoCAD 2007, Inventor 11, COREL Draw & Paint 11. Very Unreliable Network.
    Home - AMD 2.1GHZ - 512Ram, 64 Video,
    Laptop Inventor 7, Autocad 2004, Corel 11
  7. #7
    AutoCAD 2007
    Nov 2002
    1,641
    Nice render.
    Nick
  8. #8
    Senior Member
    MEP 2010
    Sep 2005
    Leeds, England
    227
    Which, the glass? I have the shininess set to give a nice reflection but it is slightly distorted by the bump map, the other materials such as cooker/fridge freezer are mirror like but have nothing to reflect as I have clipped out the front wall to enable a frontal view. see below for full model.
    Nice render.
    Thanks
  9. #9
    AutoCAD 2007
    Nov 2002
    1,641
    Nice render, bendy refraction on the fridge door is cool.
    Maybe a tad more texture to the walls ?
    Roughness adjustment may help the glass.
    Not done an acad render for a year now . Too busy with
    Inventor.
    Nick
  10. #10
    Senior Member
    MEP 2010
    Sep 2005
    Leeds, England
    227
    Quote Originally Posted by Mr T
    Thank You!
    I have a bump applied to the walls just need to alter the scale to make it visible. Renders taking about 35mins-65mins as it is need some new hardware!
    I am using 2007 havent come across the roughness slider like the earlier versions, render and material options have been dramatically changed so im still learning tbh. any tips will be very much appreciated.[/quote]
