Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Forum Newbie
    AutoCAD 2013
    Oct 2012
    5
    Default Help needed regarding some Default cursor setting.
    i have been using autocad since 2 years now. i installed 3dmax and also autocad 2013 recently. I think somehow the settings have been defaulted to some other setting. i cant really explain the issue but i am sure the pictures can.
    When i press the mouse wheel button, instead of it letting me pan around it opens up a SNAP option drop menu.
    My cursor is a SQUARE shaped with a command cross inside it, which does not allow me to hold on to the left click and select objects by making boxes. it just gives a plus sign where ever i click.
    here are a few pictures hope it makes sense.
    i want it to be the normal way like it is for everyone in the youtube video tutorials etc. so that i can start work. help is much appreciated.IMAG0188.jpgIMAG0192.jpgIMAG0191.jpg
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,993
    Quote Originally Posted by Maazy View Post
    This should be fixed by setting the MBUTTONPAN system variable to 1.
    You can set the size of said cursor in Options --> Display --> Crosshair size, respectively Options --> Selections --> Pickbox size. Alternatively, adjust the CURSORSIZE and PICKBOX system variables.
    And for sure, welcome to the Forum!
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Forum Newbie
    AutoCAD 2013
    Oct 2012
    5
    thankyou for your reply, 1 last thing i wanted help with. why cant i hold on to left click and select the objects? and for example if i want to move an object, if i select it before and then type the command why do i have to reselect again?
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,904
    Type pickfirst the Enter what does it say on the command line?
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
  5. #5
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    2,993
    As @JD Mather observed, the PICKFIRST system variable seems to be set to 0 on your station; switch it to 1.
    You didn't told us if the above advices helped you. Seems that many system variables were affected on your AutoCAD. Did you played in Options before starting to use it? The only other source for this may be from an automatically environment migration from a previous installed AutoCAD (don't believe that can be migrated from 3DMax) - was on that workstation an older version of AutoCAD?
    Regards,
    Mircea
  6. #6
    Forum Newbie
    AutoCAD 2013
    Oct 2012
    5
    hey, ya the advices work but its like i need to do them everytime again i open autocad. and i was not using any other version of autocad before this on this computer. so i dont think it can migrate any settings.
    i still cant get the grid and cursor to be normal, its still in a tilted cross and not the straight cross. i stil cant hold left click and select objects while dragging the box.
  7. #7
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,035
    Probably because your UCS is out of whack. Did you try UCS > World > Plan?
  8. #8
    Forum Deity
    AutoCAD 2002
    Sep 2006
    East Sussex, U.K.
    2,965
    PICKDRAG should be 1.
    And the plus signs wherever you click could be that Blipmode is turned on.
  9. #9
    Forum Newbie
    AutoCAD 2013
    Oct 2012
    5
    First of all thankyou for all your help, it did work for sometime for me. but then the main problem is that my settings did change and i have been going crazy on how to restore it to the normal one. i have reinstalled and uninstalled ten times now, different versions aswell, deleting all old files also of autodesk, and completely removing autodesk folder too. now the thing is the commands you all listed for me like
    mbuttonpan
    pickfirst
    pickdrag
    blipmode
    etc.
    they do work, but they are the only commands i could explain you all to which you all helped me. there are a few more settings changed which i cant explain whats happening and whats not. i will show you a picture of how i want it to be and how it isnt. the one with the grids and blue background is the normal settings which is in every other computer i have seen. but for me after reinstalling the program and opening it the first time it opens upto this black background with weird cursor which is in sign of a diagonal cross, and not a straight one even after uninstalling and deleting all document files of autodesk. and i cant hold on the click button and select the things in the green/blue box that i want. If anyone could link me up with an article or anything which would temme what settings i need to change overrall, that would be really great. here are the pictures.
  10. #10
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    Not sure why it doesn't reset when you reinstall, but I would try the following.
    SNAPANG = 0
    SNAPSTYL = 0
    PICKBOX = 7 (pick a number that works for you, 7 is a good place to start)
    CURSORSIZE = 10 (pick any number from 2 to 100)
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  1. setting of my *.ARG need to be default
    By Jhun Gonzalo in forum CAD Management
    Last Post: 28th Jul 2009, 01:28 pm
  2. LWT Default Setting
    By rdlevee in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 10th Mar 2009, 10:42 pm
  3. Setting a Profile as default
    By WannaBeCader in forum AutoCAD Drawing Management & Output
    Last Post: 25th Aug 2007, 05:06 am
  4. default setting
    By cadmuska in forum AutoCAD General
    Last Post: 30th Oct 2006, 04:28 pm
  5. Setting plotter default
    By nwmjdp in forum AutoCAD Beginners' Area
    Last Post: 12th Aug 2005, 07:49 am
